Show Printable Version 21 Likes Search this Thread
03-12-2020, 09:53 AM   #31
QuoteOriginally posted by Jonathan Mac Quote
Update - in case any of you hadn't noticed from other threads, I bought the 43mm. The two f/1.2 lenses are still for sale.
How would you compare your 50 1.7 to the fa 43?
03-12-2020, 01:18 PM   #32
PEG Moderator
Kerrowdown's Avatar
FA 43mm, K 50/1.2, A 50/1.2 - which would you choose?
I don't call her my "Special Lady" without good reason...
03-13-2020, 02:53 AM   #33
Jonathan Mac's Avatar
QuoteOriginally posted by kernos Quote
I have the FA43 and while I like it for street type photography its not my favorite for meditative shots or portraits. There's also the issue of busy bokeh particularly with foliage in the background. The K50 and A50 1.2's have exactly same optical formula which is also a similar layout to the FA77, one of my favorite lenses. So for an expressive lens it would probably be one of the 1.2's. with the A getting the nod for more usability and better coatings.
I had always thought that the K & A had different formulae, but you're right, they're the same. There are plenty of reports of the A being sharper than the K, so perhaps it's slightly updated or the elements are more precisely ground or placed.
03-13-2020, 03:41 AM   #34
bassek's Avatar
QuoteOriginally posted by WorksAsIntended Quote
My A50/1.7 is sharper than my FA43/1.9 especially in the corners (on crop).
However the 43 is better in every other aspect, evenif the A50/1.7 is a good copy too.
Seb
03-13-2020, 04:36 AM   #35
Ronald Oakes's Avatar
So, I currently have a little set aside in my lens fund and I have a few items up for sale to hopefully add to that with a view to getting an FA 43mm Limited that's up for sale in my part of the world. However, since it popped up both K & A 50mm f/1.2s have also appeared locally, for €400 & €550 respectively (the 43mm is €460). These are all used items so prices may be negotiable to some degree.
All are really dream lenses in the Pentax world. I think I'd still go for the 43mm (even though it's silver - yuck) but these other two are very tempting and don't come up often.
Which would you choose?
I would choose the 43 over any 50mm 1.2....I sold both my 1.2 lenses you mentioned as they didn't do much for me that my 1.4 lenses didn't already do !
---------- Post added 03-13-20 at 04:39 ----------
Initially a Very Wise Choice !
03-13-2020, 05:54 AM   #36
johnha's Avatar
QuoteOriginally posted by Ronald Oakes Quote
I'd agree, I haven't used either 50/1.2, I know they get a lot of praise and are on many people's 'must have' lists, but I'm not really that bothered about the dreamy appearance most mention about it (they may make a superb portrait lens on APS-C though). The FA43 is a fantastic focal length, it's really well built, handles superbly, responds well to the screwdrive AF and manual focus on an LX. Mine is plenty sharp enough, and easily my preferred 'standard' lens on the K-1.
03-13-2020, 06:34 AM   #37
pres589's Avatar
This is coming from a film shooting perspective, where I only use manual focus bodies, which I think is an important distinction. I'm in the market for a K 50 1.2 (or a Tomioka-type 55mm f1.2 like the Ricoh XR) and not so interested in the FA 43 mostly due to the faster aperture (I already have an M 50 1.7 and an F 50 1.7 which I think are very nice indeed) and how the FA 43 renders out of focus "busy" backgrounds. It's distracting at times and just not something I really want in a lens. While I really like 40mm on full-frame, and think the 43 would be a nice addition to my collection of glass, I don't see that lens being worth the money over a Pentax 50 1.7. The usable sharpness of the K and A 50 1.2's wide open, and wide max aperture, makes these lenses quite appealing for using with film where there isn't as much latitude in sensitivity. On a digital body I don't think I would bother and would look for a DA 40 XS, FA 50 1.4, or DA*55 1.4 instead. A DA 40 and the K-1 seems like a dream package.
03-14-2020, 07:53 AM   #38
Wasp's Avatar
I have recently acquired a K 50mm f/1.2. It had fungus so it is in the shop now. Here is one of my first efforts. Can't wait to get it back.
03-15-2020, 06:42 PM - 1 Like   #39
The 43 and 50s compliment each other. I ran with both the K50/1.2 and the A50/1.2 alongside my 43 until the A was replaced by the DFA*50. The 43 is a bit more analog but still has it uses, as it is definitely less of a look at me type lens than the 50s, wider frame of view too and has a lovely reportage subject isolation as it is of a older generation design and resolution is weaker as you cross the frame at wider apertures. Bokeh of the 50/1.2s is more than usable but prone to coma flare at 1.2 resulting in outlining. The newer 50 is much better behaved.
Size wise the 43 is a ballerina with the latest 50 being a sumo wrestler and the 50/1.2s acting at stubby 85s with a solid chunk of glass out front.
Summary of all this, the 43 is my default lens on the K-1, the other 50s were taken out if needed. Push to the shove and I'd take the 43s with a 50/2.8 macro over all the other 50s. The uber DFA* is all of them combined but it's a big hunk of glass and reassuring expensive to go with that. The 1.2s give you a specific look but are a step up in difficulty levels when manually focusing @/1.2, the 43 can have busy Bokeh at times but your keeper ratio will be higher. So get a 43 first and foremost then rotate the other 50s in as you work your way through them until you find the one you like.
03-18-2020, 08:50 AM   #40
Wheatfield's Avatar
I would choose to save for a little longer and spring for the D FA* 50/1.4.
Full disclosure: I am a 50mm lens junkie.
03-19-2020, 01:48 AM   #41
I would be saving for a lot more to get that. I paid €400 for the 43mm. The DFA* 50mm costs €1000. Besides, it's far too big and heavy for use in the way that I would use a normal prime.
03-19-2020, 07:25 AM   #42
Wheatfield's Avatar
That being the case, I do own both the A50/1.2 and the FA43LTD. Of the two, I prefer the 50mm lens.
43mm, 50mm, fa, k-mount, lenses, pentax lens, sale, slr lens, world
If you had your choice, who would you choose? Tonytee General Talk 43 10-01-2019 05:53 PM
Sigma 17-50 or 17-70 - Which would you choose tonksj Pentax SLR Lens Discussion 21 07-24-2018 06:20 AM
Fa 43 vs. Da* 55 - which "normal" would you choose on FF? bpv_UW Pentax SLR Lens Discussion 31 09-09-2015 12:04 PM
If you could only spend $600 dollars for a new camera, which would you choose? OldNoob Canon, Nikon, Sony, and Other Camera Brands 36 02-14-2014 07:25 AM
Moving beyond the basic lenses, which would you choose? Or, spending the tax return mikem Pentax SLR Lens Discussion 25 02-17-2010 06:50 PM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
