Originally posted by boriscleto On the other hand the 55-300 WR isn't an IF lens, so it doesn't focus breath. It was always a nice close up lens, which is nice for a nature walk around lens.
Originally posted by mikesbike Unlike the PLM version, it does not feature internal focus design, so it is not subject to to "focus breathing" which will shorten effective focal length at closer focus distances. So if you get up closer to a bird for example, you might be able to get close enough to get a frame-filled image without causing the bird to fly off before you can get the shot.
This is true, but I think it needs to be put in perspective. I don't think it matters in practice.
For the uninitiated, I'll start with the basics. What we are talking about here is the effect of the difference between the focus mechanism of the 55-300 f4.5-6.3 PLM lens on the one hand and the screwdriven 55-300 f4-5.8 models (DA, DA-L and HD-DA WR versions) on the other. The PLM (like most modern zooms) has internal focus (IF) - that is, the length of the lens doesn't change when focusing in and out. The screwdriven models are non-IF- as you focus in and out, the length of the lens changes. IF lenses are more prone to focus breathing (explained here:
https://photographylife.com/focus-breathing). That means that at short focus distances the field of view (FOV) will be noticeably wider (ie less magnified) than the FOV at the same focal length when focused at infinity.
Some lenses are more prone to focus breathing than others. The DA*60-250 f4 is often cited as an extreme example - the FOV at 250mm, when focused on a point not too distant, is significantly wider than the 6.5 degrees diagonal that you would expect of a 250mm lens on an APS-C camera. The effect is at its strongest when the lens is focused at its minimum focus distance (MFD) - that is, the closest point at which it can focus. A zoom lens reaches its maximum magnification when zoomed in as far as it will go (250mm in the case of the 60-250) and focused as close as it can (ie at its MFD). In the case of the DA*60-250, its maximum magnification (that is, at its MFD of 1.1 metres and when zoomed in to 250mm) is only 0.15x. In other words, the butterfly you are focusing on will be recorded by the sensor at only 15% of its actual size. This means it isn't great for any pseudo-macro.
The focus breathing on the 55-300 PLM is far less pronounced. At its maximum reach (300mm) and focused on a subject at its MFD of 0.95 metres (ie 95 cm), its maximum magnification is 0.3x (ie a subject is recorded at 30% of the original size). That's pretty useful for a tele zoom. (If it were a Sigma, they'd be calling it a "Macro": e.g.
Sigma 18-300mm F3.5-6.3 DC Macro HSM (Contemporary) Lens Reviews - Sigma Lenses - Pentax Lens Review Database - 0.33x.) By comparison, the maximum magnification of the screwdriven 55-300 models is slightly less - 0.28x (ie 28%).* The difference is that the MFD of the screwdriven models is 1.4 metres. You can argue about which is better - as @Mikesbike points out, getting maximum magnification, or close to it, at a greater distance to subject might sometimes mean that the subject is less likely to be scared off. Perhaps it's also less likely that the subject will bite you (we think about these things a lot in Oz
). On the other hand, in many situations a shorter MFD is preferable (as those with older tele lenses with typically longer MFDs can attest). It's very frustrating when you miss a great photo op because your obliging subject has come too close - something I often experienced with the DA-L 55-300 f4-5.8. Personally I'd take the shorter MFD for the same magnification every time.
So what about other focal distances? I did a field of view comparison between the DA-L 55-300 f4-5.8 (one of the screwdriven models - same optical formula as the other two) and the DA 55-300 f4.5-6.3 PLM here:
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? - PentaxForums.com Summary of results:
1. At 1.4m from the subject, the FOV at 300mm on the PLM is equivalent to 210mm on the DA-L.
2. At 2m from the subject, the FOV at 300mm on the PLM is equivalent to 230mm on the DA-L.
3. At 3m from the subject, the FOV at 300mm on the PLM is equivalent to 260mm on the DA-L
4. At 6m the PLM has just a little more magnification (narrower FOV) than the DA-L at 260. The difference between the PLM at 300mm and the DA-L at 300mm is apparent, but not massive.
To illustrate the 4th point here is a comparison between the FOV of the PLM (first image) and the DA-L (second image) zoomed to 300mm with a subject about 6 metres distant:
My comment on these results is that although there is some focus breathing with the PLM at distances to subject between 1.4m and 3m, it is not greatly significant, because the maximum magnification of the PLM for close subjects is about the same as the screw-driven version. In other words, if you want more magnification with the PLM, get closer; if you can't get closer, it won't matter hugely (especially if you have a 24mp or 36mp sensor, which allows plenty of scope for cropping). By typical distances for birding (e.g. 5m or more), where you want maximum magnification at 300mm, focus breathing is negligible.
So all in all I don't think the difference in magnification is a significant consideration in choosing between the PLM and the screwdriven models. IMO, the only reasons to choose one of the screwdriven models over the PLM are: - price (the screwdriven models provide very good resolution and can be a good bargain buy); or - for use on an older body which doesn't support KAF4 (e.g. K-5 series or earlier).
Footnote: * When I compared the PLM and the DA-L at 300mm at their respective MFDs, I got significantly more magnification from the PLM than from the DA-L, in the order of 10% more. (See posts #37 and #38 in the thread linked above.) But that might have been an error on my part.
