Originally posted by barondla If the SDM fails completely can the lens still be focused manually?
I have a DA* 50-135 SDM. It was repaired several times, including replacement motors twice and the general focusing mechanism once. In one of the failures, the lens would not autofocus and it would focus manually only in one direction; it seemed to be jammed. In the other SDM failure instances, it would focus manually with no issue.
I converted the lens to screwdrive in 2016 and it has worked flawlessly since then.
- Craig
