02-08-2020, 08:13 AM   #1
Pentax M 50mm f1.7 - stops per click
I am completely new to anything Pentax so excuse me if the question is really stupid. How many stops per click does this lens should have?
I seem to be getting one click between 22-16 which would indicate a full stop per click. Then two clicks between 16-11 which should be half stop per click. And finally two clicks between 2.8-1.7 which might be a full stop to 2 and then a half stop. Is this normal?
02-08-2020, 08:48 AM   #2
QuoteOriginally posted by peter.d Quote
1.7 to 2 is a half stop.
2 to 2.8 is full stop [updated].
Quite a few lenses skip the half between 16 and 22.
So, yes, normal for that lens in particular.
02-08-2020, 09:10 AM   #3
QuoteOriginally posted by gavinhw Quote
2 to 2.8 is also half.
2 to 2.8 is a full stop.
The click between 1.7 and 2.8 could be 2.4, which is a full stop from 1.7 and half stop from 2.8
Or could be 2, half stop from 1.7 but a full stop from 2.8
I used the lens for many years but in the eighties, more than 30 years ago, so I'm not quite sure.
02-08-2020, 09:27 AM   #4
QuoteOriginally posted by CarlosU Quote
Yes, you are right, it is a full stop.
I played with the Pentax ME that came with the lens and I am getting one stop in shutter speed between the second and the third click so that is one stop in aperture. The first click does not change the shutter speed so that is likely to be a half stop in aperture. The camera lightmeter has one stop resolution.
1.7 -> 2 half stop for the first click
2 -> 2.8 full stop for the second click
2.8 to 16 half stop for each click
16 -> 22 full stop for the last click
50mm f1.7, click, clicks, half, k-mount, pentax, pentax lens, pentax m 50mm, slr lens
Click Stops on Pentax 6x7 lens ? milarico Troubleshooting and Beginner Help 2 07-27-2011 10:10 AM
Click..Scroll.. Scroll.. Click.. Hello! kmount Welcomes and Introductions 6 07-23-2011 04:27 PM
Initial click-stops on an F2.8 M lens dosdan Pentax SLR Lens Discussion 4 05-24-2008 06:34 AM
8 bits per channel -vs- 16 bits per channel Ed in GA Digital Processing, Software, and Printing 5 03-25-2008 09:02 AM
Problem - K100 with new batteries - click click click. jsundin Pentax DSLR Discussion 13 08-28-2007 02:09 PM
All times are GMT -7. The time now is 06:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
