Originally posted by zapp That’s why you call the lens a 200 and not a 200mm. Today the tolerances are tighter. 1% Offset I think. Aperture has different offset. Filter diameter is always wider than lens diameter, so differences are even worse.
I think some would argue that tolerances were tighter back in the day. Under the Japan Camera Inspection Institute, there were tight tolerances applied to products for export. This was done to make sure Japan's reputation for making cheap tin toys and cheap radios in the 40's and 50's was transformed into a reputation for precision and accuracy. A lens had to be within a few percent of its marked focal length to meet approval. Same for apertures, and shutter speeds, etc. etc.
The JCII stickers disappeared around 1990 (anyone know the exact year?). This was era of the early wonderzooms, and lenses with internal focusing, which changed their actual focal length depending on focusing distance. While a traditional unit focusing lens extends its focal length as you focus closer, internal focus and front focus zooms can do weird things - but they usually lose focal length. So your current 18-270mm is likely a pretty accurate 270mm when focused at infinity, up close it may be lucky to break 200mm. To the owner and user of such a lens, that doesn't likely matter much, but it would have driven the JCII mad.
But technically, yes, things could be "fudged" back in the day, or today. For marketing reasons, a lens measuring closer to a 1.8 aperture could be sold as a 1.7, and still be within JCII tolerance.
