Originally posted by baro-nite Since you have crop-sensor bodies, the Venn diagram for your criteria points to a crop-sensor lens. Meaning, optically sound wide angle lenses tend to be expensive, so one designed for the smaller sensor will likely be a better value for you. There's a DA 15 Limited in the forum marketplace you might want to check out.
Originally posted by Bertrand3000 Pentax DA 10-17 if you want to try fisheye (very wide angle of view, fisheye effect can be used for artistic purpose).
Sigma 10-20 F3.5 if you prefer quality wide angle without much distortion.
Originally posted by ehrwien And in almost the same range as the Sigma 10-20/3.5 are the more affordable Sigma 10-20/4-5.6 and Tamron 10-24/3.5-4.5, but they also offer a bit worse image quality than the Sigma 10-20/3.5
I think you should be able to get a Tamron 10-24 or Sigma 10-20/4-5.6 for about 150-200 ($/€) if you keep a patient eye on the used market in your area.
Lots of good advice. I have the DA 15 and it’s one of my favorites. I have had the Tamron 10-24, good lens but prone to flare at times. I have no experience with the Sigmas or Pentax ultra wide zooms. As far as manual focus goes; it will be hard to find anything under 28 that is low cost, without just getting real lucky. A few third party Manual focus lenses have come out in the last few years, but I don’t have any idea what the used market holds as far as price and availability. Do you know what types of photos you wish to take with the lens. I use the 15 for tight spaces, buildings, occasional landscapes. The 15 has very good rendering of colors which makes it more useful than some other lenses I could use. Good luck in whatever you choose.
