02-11-2020, 10:15 PM   #1
Question about Pentax 60-250 lens.
Can the Pentax 60-250 zoom be used on a tripod mounted Pentax K-1 without using the lens tripod collar? Or, is it way to heavy to hang from the body?
Thanks,
barondla
02-11-2020, 10:30 PM - 1 Like   #2
I t is a reasonably heavy lens, it comes with a tripod foot, physics would make me go with the tripod foot rather than using the camera to support the lens. I would use the camera in an emergency if the foot wasn't there, however why take the risk
Good luck
02-12-2020, 02:01 AM - 1 Like   #3
Digitiser of Film
BigMackCam's Avatar
It's too long and heavy, IMHO. You'd be exerting considerable leverage on the camera's tripod socket and lens mount, not to mention the tripod head. When I'm walking around with the 60-250 on my K-3, I support the lens so that it's not putting strain on the mount.
02-12-2020, 02:15 AM   #4
Michail_P's Avatar
Better go with the foot. Every lens that has a tripod foot should be supported by it, or else the camera mount (and equally the lens) takes too much stress by the unbalanced weight. K-1 is about 1000gr, lens is around 1100(?).... and considering the length, it should be supported by foot.
02-12-2020, 04:49 AM   #5
joergens.mi's Avatar
I've used ist several times on a good tripod, using the body in the arca-swiss mount, because the foor was at home. It works fine, but swings more. But if the shake reduktion is on it work stille fine.
I would prefer the foot, but it works the other way round. With an arca-swiss plate the Body ist strong enough even to hold the 150-450 (forgotten the arca-plate for the lens) - it works, but mounted with the lens it works much better.
02-12-2020, 05:01 AM   #6
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by joergens.mi Quote
But would you want to put that much weight and leverage on the camera's lens and tripod mounts? I know they're robust, and it's certainly possible in a pinch, but I question whether it's advisable for regular and/or protracted use.
Each to his or her own, of course...
02-12-2020, 06:00 AM   #7
Seeker of Knowledge
aslyfox's Avatar
I would use the foot
why take the chance of damage if you don't have to ?
reminds me of what my dad said
" you paid for that strap on the camera, use it "
likewise, you paid for the tripod foot on the lens - - -
02-12-2020, 06:09 AM   #8
bdery's Avatar
The upcoming Pentax 70-210mm F4 will be roughly the same weight and does not come with a foot. That suggests the 60-250 should be fine.
That being said, it does come with a foot and balance / vibration control wil absolutely be better with the foot.
02-12-2020, 09:34 AM   #9
60-250 1115g w/hood
70-210 859g w/hood
02-12-2020, 10:20 AM   #10
bdery's Avatar
QuoteOriginally posted by caliscouser Quote
60-250 1115g w/hood
70-210 859g w/hood
And the difference is roughly the weight of the foot itself... I can check when at home but I'm guessing the foot is at least 200-250g.
02-12-2020, 10:22 AM   #11
sbh
sbh's Avatar
With a ball head, you'd need a very large one to have it reasonable stable.
If you have a 3-way head, it works better but still not ideal. The 60-250 is very long wich makes the entire thing quite a lever. If possible, move the quick-release plate to the front as far as possible. There are arca swiss quick release plates that are a few cm long and you could move the camera backwards a bit.
But in any case I'd prefer using the foot.
Is yours missing or do you want so save weight?
02-12-2020, 01:11 PM   #12
Those weights exclude the tripod foot for the 60-250.
That foot would be an additional 115g on top of the 1115g
02-12-2020, 02:16 PM   #13
He didn't ask explicit for regular use.
I said it is possible and I think it wouldn't damage the camera. I'm using a longer arca-swiss plate, I would never mount the camera directly with a 1/4 screw to a tripod,
To use it this way isn't the best solution, when I use the lens foot I have a better balance and less swinging of the system.
When trying to work on a more professional level, i would always mount the camera-lens system in balance to the tripod, and therefore using the foot.
02-12-2020, 02:25 PM   #14
Digitiser of Film
BigMackCam's Avatar
I wasn't calling you out. My question to you was sincere - not rhetorical and/or critical. My apologies if I didn't make that clear
Combined with your previous post, that information will - I'm sure - be valuable to the OP.
Thanks for clarifying
02-12-2020, 06:57 PM   #15
Yeah, but that is not weight sticking way out beyond the anchor point- think leverage/weight relationship. Along those lines, the lens's length also is part of the situation, as well as design- how much relative weight in the longer half vs the shorter half of the lens?
My FA 300mm f/4.5 did not come with a tripod foot, while the previous "F" version did. But the "F" version as I recall was different in its design, while the FA version was more svelte- I'm seeing 935g and 160mm long with a 67mm filter size, and without the quite long hood.
k-mount, pentax, pentax lens, question about pentax, slr lens, tripod
SMC Pentax DA 60-250 F4 vs Sigma DC 18-250 F3.5-6.3 thepurplehornet Pentax SLR Lens Discussion 12 03-25-2019 10:22 PM
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 25 12-30-2017 01:49 PM
For Sale - Sold: Pentax DA* 60-250, 16-50, Sigma 10-20 3.5, Pentax 18-250 millertime Sold Items 9 10-04-2015 07:23 PM
All times are GMT -7. The time now is 03:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
