02-12-2020, 08:35 PM   #1
18-135WR or 17-70 f/4?
Originally l wanted the 18-135 for my first Pentax body. l assumed the 17-70 would be "high dollar" because of the constant aperture. Checking prices, a used one is close in price to the 18-135. ls the 17-70 WR? The most important feature to me is WR.
02-12-2020, 08:46 PM - 1 Like   #2
twilhelm's Avatar
No, the 17-70 is not WR.
The DA 17-70 gets mixed reviews around here because of the SDM. I’ve had it for many years now and never had an issue. The image quality is superb and I used it for weddings and events as my go-to lens. I did find, as many users had, the focus was hit or miss on the older bodies, ie the K10 up to the K5. Once I paired it to the K3, it became a much better lens, and on the KP, it is an entirely new lens, quick to focus and accurate.
But if you need WR, go with the 18-135 or if you can live with a smaller zoom range, the 20-40.
02-12-2020, 08:52 PM - 1 Like   #3
The 16-85 is the WR replacement for the 17-70mm. Despite not having the fixed aperture, it's a phenomenal lens.
02-12-2020, 08:58 PM   #4
The 20-40 is not enough range. Since the 17-70 is not WR, looks like the 18-135 is my best bet. Thanks.
02-12-2020, 09:01 PM - 1 Like   #5
Just1MoreDave's Avatar
The DA 17-70 isn't WR. For some reason it has an O ring on the mount as if it was. Who knows why. It also has an SDM motor which carries a higher than normal risk of failure. Because of those two issues, the 17-70 isn't that popular.
The DA 18-135 is WR. It has a different type of focus motor which is much more reliable. It's a pretty good kit-type lens. It does have optical flaws such as vignetting and not very sharp corners, but the zoom range and center sharpness make up for it. It is capable of producing great images. I take mine on vacations because of the versatility. It won't be great at everything but it's a useful tool.
02-12-2020, 09:07 PM   #6
That one is out of my price range.
02-12-2020, 09:43 PM   #7
18-135 and pair it with one of the 55-300s, you can cover a lot of ground.
Neither is perfect, but both are pretty good and consistent performers.
Check out the18-135 reviews here
There used to be a thread with all kinds of great shots members had posted taken with the 18-135, but I can't find it now, I had a couple in it.
There are two WR versions of the 55-300, the newer PLM, which only works on newer bodies, or the older (but not old) HD-WR.
If you are buying a new Pentax APSC body, no problem with either, but if you are looking at an older, used body, you should check compatibility of the PLM
Check Lens Compatibility with Your Pentax Camera
Let us know what you do, and how you like your choice
02-12-2020, 09:47 PM   #8
happy with my 18-135 for what it is, beyond that I prefer prime lenses, although the 50-135 is very good.
02-12-2020, 10:21 PM   #9
RGlasel's Avatar
QuoteOriginally posted by K-Three Quote
Still is, and here is the link. If someone is visiting that thread for the first time, they might want to start with the latest pages and work back, the first 50 of 214 pages have lots of dead links to Photobucket and other photo-sharing services.
02-12-2020, 10:43 PM   #10
QuoteOriginally posted by RGlasel Quote
Thanks, I could not find it earlier,
02-13-2020, 01:43 AM   #11
johnha's Avatar
QuoteOriginally posted by Just1MoreDave Quote
I haven't had any issues with the SDM in my 17-70, on the whole it's a good walkabout lens. Just about wide enough, just about long enough, just about fast enough and just about compact enough.
When I bought it (2012 ish) I think I read it had 'reduced WR' somewhere but can't find any reference to that now.
02-13-2020, 06:21 AM   #12
jddwoods's Avatar
QuoteOriginally posted by johnha Quote
The mention of possible reduced WR is in the In depth review of the DA 17-70 that is available in this forum. The in depth review is a comparison of the DA 17-70 to two earlier Sigma versions of their 17-70.
As for me, I bought my DA 17-70 new in 2009 and used it on my K10D, K-5 and K-3 bodies. I had autofocus issues with this lens on all three cameras. When it was new, the autofocus was reliable and fast from 17 up to about 50. From 50 to 70, it was hit or miss where it periodically hunted and failed to lock focus. This was also observed in the in depth review. Around 2014, I started having issues getting the autofocus working on startup, especially if the lens was not used for a week or more. The SDM finally died about late 2015 and since then the lens was not used. in 2016 I looked to either repair it, get the 18-135 or look for a good used 16-85. I ended up getting a like new used 16-85 and am very happy with this lens.
My suggestion to the OP is to proceed with caution in purchasing the 17-70 due to the prevalence of SDM issues. Reading the reviews on this forum and at B&H website is suggested. The 18-135 and 16-85 both use DC motors instead of SDM. Based on my experience with my 16-85, I have zero issues with its autofocus performance.
One other concern with the 17-70 is the focus has a very short focus range. Meaning if the autofocus fails, it is very difficult to use as manual focus lens.
If I knew that repairing my 17-70 would give an improved and more reliable autofocus motor, I would get it fixed, but still, I prefer the 16-85. It is sharper, has a wider zoom range and is WR which more than offsets the constant aperture advantage of the 17-70
02-13-2020, 12:08 PM   #13
Unregistered User
Guest
I think that the 18-135 is a wonderful lens. It is actually quite good and I would not qualify it as a kit-type lens (to be honest: Every not limited or Star lens qualifies for kit-type lens). It is much more than that. It is sharp and it produces lovely colours and it is fun to try close up pictures with. AF is fast and silent. But it is a lens that you have to learn to appreciate. I bought it for the Samsung GX-10 and it replaced the two kit lenses 18-55 and 50-200 and a lot of my old Pentax lenses. What struck me was that it resulted in better pictures than with my old primes and my A F3,5 35-105. It gave even better results than my old Star A 1.4 85mm. Better colours and sharper.
When I mounted the 18-135 to my K-7, which I bought in 2017, it got a bit of extra sharpness and colour. I hope that telling my experience with the lens helps. I just bought it and am pleased with it.
02-13-2020, 02:34 PM   #14
Wingincamera's Avatar
I purchased the 18-135 as a kit lens when I purchased my KP and It is a good lens, but above 70 to 80mm mine is not as sharp as in the lower zoom range. As far as the WR goes, mine has been in lots of rain, even a direct hit during a water balloon fight and no problems with lens or camera. I have since gathered more lens and seldom use the 18-135 anymore unless I only want to carry one lens with the possibility of wet weather and I don't want to change lens. Example would be a sidecar trip from Washington state to Yellowstone Park and it pretty much rained the whole trip. I had other lens, but being in the open weather I wasn't able to change lens. I think the 18-135 is a good value and overall a good lens.
k-mount, pentax lens, slr lens, wr
K-5 with Sigma 17-70 vs 17-50 vs Pentax 18-135 vs Sigma 18-250 dr_romix Pentax K-5 20 08-25-2012 07:19 AM
sigma 17-70 vs Tamron 17-50 vs Pentax 17-70 dr_romix Pentax SLR Lens Discussion 19 07-01-2012 10:15 PM
18-55WR vs 18-135WR ? hoanpham Pentax SLR Lens Discussion 11 02-14-2011 05:48 AM
All times are GMT -7. The time now is 07:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
