Originally posted by tokyoscape sample,DA15 - 3 images stitchFA20 - 3 images stitchDA21 - 3 images stitchF28 - 3 images stitchDA*55 - 3 images stitchFA50 f2.8 - 3 images stitch (this is the lens I feel sorry letting it go.)100wr - 6 images stitch (just sell this lens and I start to feel sorry now!)
Oh yes. You have here fantastic stitched panoramas. You managed to stitch from 20mm, it's wide already. It could be that the many features and lines contained in each frame of city secenery help for stitching. When stitching indoor archi, there can be entire areas of frame without detail, making it harder to align frames relative to each other.
---------- Post added 20-02-20 at 08:37 ----------
Originally posted by JensE Hugin normally calculates its lens distortion model from the overlap of the images and optimizes the overall fit by tuning the distortion model.
Sure, hugin documentation also says so. I've read that some kind of lens distorsion ("moustache"?) can't be corrected by the a,b,c model, and I was assuming that a lens having significant distorsion might also have some of that distorsion not fully corrected by the a,b,c model, leading to mismatches between frames.
---------- Post added 20-02-20 at 08:40 ----------
Originally posted by Kobayashi.K You can clean up an image until the result conforms to the idea of an end-result you have in mind.
Agreed. At the end, it's the creation of the final image that counts, depending of photographer's intent. That's precisely how fine art photography is defined, bringing the photography creation process a bit closer to the painting process.
