Originally posted by AfterPentax I have a number of old lenses amongst which the F F1.4/50mm, A F1.4/50mm, F4/K200mm, Takumar Bayonet F2.5/135mm and the F3.5/35-105. I have tried all these lenses on my different camera's: Samsung GX-10, K-7, K-01 and the K-3II. The results are always the same. They are soft, very soft I would say. A professional photographer once told me that they are all designed for film camera's and that it is a problem to adjust digital camera's, that is the sensors, to that old glass. So it is easier for the manufacturers to design glass that is adjusted to digital camera's. They all show sharp results through the viewfinder but the result is soft.
For me the old glass was a reason to buy the Samsung at the time, I was under the impression I could use all that old glass. But unfortunately, all that new glass is so much better than the old ones on a DSLR.
So, is there a reason why old glass gives a much softer result than new ones? Is there indeed a technical reason for it or is it just "a fairy tale"? Or do they give better results if I used a K-1?
And to be honest: I shot a lot of pictures in the film era and I am not inclined to start again with a film camera now I have experienced all the joys of digital. The only lens that gives a sharp result is the F F4/28-70, but that one is a bit dull on the colour front.
Some lenses are better than others. Some of the lenses you mention are good on digital, though they need to be stopped down a bit, some are OK, but not great. The F 50/1.4 is getting decent by about f/4 and quite good at f/8, but then, that's how it was on film also. The A50/1.4 is quite good on digital, but needs to be stopped down a couple of stops, just like it was on film. The same with the 35-105 f/3.5
If your experience showed them to be "soft, very soft", I question if your camera was the culprit (AF adjust not being done) or an out of calibration focusing path, the lenses in question were broken, or if, in the case of the manual focus lenses, you were actually focusing them properly to begin with.
My point here is that your premise " old glass gives a much softer result than new ones" is very suspect.
Reason: spelling
