Originally posted by mikesbike
Perhaps the best overall solution is to keep the DA* 50-135mm and also acquire the DA 55-300mm f/4.5-6.3 WR PLM, which does have WR and HD coatings. this lens is not all that expensive, is very compact and lightweight, and should bring very fine results in good lighting conditions. For lower lighting conditions, this is when the DA* 50-135mm can deliver the f/2.8 greater aperture range. I have the older DA HD 55-300mm f/4-5.8 WR which is screw-driven, and has improved AF speed with my KP, and IQ is very satisfactory. I also have had the DA* 50-135mm for around 10 years, SDM still works fine (knocking on wood), I am very fond of it, and basically that is my general plan between these two lenses. If I have good lighting and also need more zoom range, I go to the 55-300mm. If I am dealing with low light situations, it is the DA* 50-135mm for sure.
My other alternatives for longer tele range are my DA* 200mm f/2.8 (but its SDM is slightly slower than the DA* 50-135mm), or my FA* 300mm f/4.5 which is screw-driven with very fast, accurate AF on my KP.
Thanks Mike!
I got the 100-300mm range covered with my Sigma 100-300mm f4. She is the real deal. I got also a Pentax F* 200mm f2.8 but she doesn't like racing. Its very bad at front lights and fringes a lot of purple in motion images.
I had a 55-300mm before, the first one and can be quite erratic at focusing i believe (maybe the cameras I paired it with: k110d and kr weren't the best either)
I am specially looking at that 50-135 or 50-150mm range because is what I need in some cases and i find the 50-135mm screwdrive a bit too harsh to work with at speed.
The *200mm and *300mm would be great solutions but again a bit out of range.
Another option could be the Pentax 60-250mm but then i got extra range i have to pay for that i have covered with my Sigma.
