Originally posted by biz-engineer Did you experience lots of lens swapping with that combo?
Not really, I use the 28-105 by default. If 28mm is too tight for a couple shots I just work around it which isn't normally a problem outdoors... I have the 20mm as a "just in case", I mount it if I go indoors or into a more or less confined space where I wouldn't need more than 50mm, then I change again once I'm done: in a couple of fortresses in India I kept it on for more than an hour straight.
I purposefully bought the M20/4 because it's the only UWA I can be bothered to carry with me all the time: a 24/2.8 wouldn't make *that* much of a difference compared to 28mm, and anything wider than the M20 would be too heavy* for something that has a decent chance of not leaving the bag...
*Exceptions being the Tamron or Tokina 17mm, which are larger but not outrageously so... but would cost about the same with noticeably worse IQ.
Another option I considered was the gorgeous 17/4 Fisheye but I wasn't sure about having to spend time to linearize every other shot
