Originally posted by cport Hopefully.
Anyway, it shows at least the Ricoh's QC.
You really need to read the lens rentals.com page on sample variation. If you replace Ricoh's QC with standard camera industry QC then you're on to something. You can buy a $15,000 lens from canon, Nikon or Sony and have QC issues.
So, that begs the question, if people don't understand industry wide QC and base a whole report one copy of a lens, is it not incumbent upon them to pay at least lip service to sample variation. After all, many have sent a lens in to a repair depot and have it sent back as "up to spec." when it still performed poorly. Lensrentals.com points out in their article most facilities do not have the equi[ent to test for decentering or mis-aligned lens elements. Such equipment would be extremely expensive. The guy at lens rentals makes adjustments with shims using pretty much informed trial and error. He knows of no facility to send his lenses out where repairs can be done to his satisfaction
While it would be great if they only shipped lenses from the top half of the QC curve, that would double the cost of less as we'd still have to pay for the bottom half. It's sad.
On the positive note, my first DA 55-300 was broken in half my second one is much better right out of the chute. I paid for two lenses, but the one I have now, I'll never part with. I also suspect my 18-135 is from the high end of the curve, but I got lucky.
The sad thing is when people take your advice, look at your pictures, buy the lens and then don't get the results you did. It really is a crap shoot.
Looking at my own expereince, most of my lenses performance is acceptable. My first DA 55-300 was on the low end of the scale (but I was still happy using it, my new one is just better) and is the only one of my 10 or so Pentax lenses where a noticeable performance was likely to improve replacing the lens. My conclusion is industry QC keeps lenses affordable. Adding a whole new level of QC to make sure every lens is above the current median for sample variation would be very expensive and not necessarily all that worthwhile. Most image don't depend on good sharp lenses for their IQ. That being said, if you get an excellent lens at any focal length don't sell it. The thought that you can buy another that's just as good may not in fact be the case without two or three tries.
A lens comparison without reference to the lens rentals documented sample variation for that lens is probably not worth a whole lot. You need to know how 10 less tested out, not one. And you need to know where on the curve compared against other copies of the lens the lens tested out.
The biggest problem with these comparisons is that there is nothing in it for the camera companies to run the tests themselves. If people had a way fo selecting only the best performing lenses from a production run, who would buy the still within spec, but poorer performing lenses? You'd have to charge more for the high performing ones and less for the lower end of the spectrum. A totally unworkable arrangement.
Sample variation is just something you have to live with.
