Originally posted by bertwert Anyways, I'd be quite happy to hear some further thoughts on this
@bertwert, I don't have any experience with the DA* 16-50, but I do own a DA* 50-135 which I converted to screwdrive after it experienced 5 SDM or mechanical failures in 2012-2013 (4 repaired under warranty). I don't mind the screwdrive, and its autofocus has been flawless.
I don't think that I would buy another DA* SDM lens, based on my experience with my 50-135. However, as you indicate, converting to screwdrive is a fair remedy.
I own a DA 18-135mm lens. I've used it fairly often, but to be honest, I was never 'wowed' by its images, although I've seen a number of perfectly acceptable images here on Pentax Forums and many of mine are ok. It's a versatile lens, to be sure, and it's pretty sharp in the range of 20-50 mm or so. When I got it, I was looking for a zoom lens mainly in the 16-50mm range, so I considered its longer reach to be a bonus. Quite a few folks here attest to its good value-for-money, to which I would agree. I'd suggest that a detailed research on PF and other sites will give some good insight into the lens.
When my 'camera kitty' reached a sufficient level, I looked for a replacement for the 18-135. I ended up deciding that I'd be comfortable with a two-lens zoom kit for general purpose walk-abouts, including the 50-135 and a wide-to-near telephoto. I settled on a DA 20-40mm (which is likely out of your current budget at roughly CAD $730). For what it's worth, here are my notes from another thread:
Sigma 17-50 vs Pentax 20-40 - PentaxForums.com
I'm very pleased with the 20-40, and haven't used the 18-135 for a while. I wouldn't suggest that you look at the 20-40 now, unless you're willing to save up more funds. Also, the Sigma 17-50 that I refer to in that thread is not weather sealed, so it might not be ideal for some types of outings. Amazon currently is listing the Sigma for CAD $399 (1 left in stock), which is a very good price, lack of WR notwithstanding.
I also considered the D-FA 28-105mm. It is also relatively pricey, unless you can get a used copy. It's not overly wide on APS-C, which might be a disadvantage to you.
The DA 16-85 seems to receive very good reviews and ratings.
It might be worth considering whether you would prefer a single lens with a wider focal length range, or a couple of lenses to split the range. The 18-135 covers a good range that will cover many subjects. In my experience, I find that if I really need an extended 'reach', it's usually well beyond 135mm. My philosophy is that I prefer better image quality over the advantage of having a one-lens solution; yes, I might not have the right lens mounted for a sudden opportunity that disappears quickly, but I've not missed too many shots with a two- or three-lens kit. Generally, when I'm not set on one type of subject, I find that I can get good shots with whatever lens is mounted on the camera.
I acquired my 18-135 at a fairly good price within my budget at the time, and used it happily enough for several years, including on several trips.
- Craig
