04-10-2020, 08:24 PM   #1
Brand of bayonet lens hood compatible with Pentax? (16-85mm/72mm esp.) | SUCCESS!
I dropped the lens hood for my brilliant 16-85 Pentax lens on the beach. A new one is about $75 AUS.
Has anybody replaced theirs with something else?
I'm seeing lots of 72mm generic replacement for canon etc on eBay, but none mention Pentax.
Is this a lucky dip?
Thanks.
04-10-2020, 11:05 PM   #2
Any "generic" lens-hood advertised as suitable for a 16mm lens, with the same thread size as your lens, should be suitable. However, many eBay sellers, deliberately or otherwise, advertise lens-hoods as "will fit" when it is reasonably obvious from the images that it is unlikely to be "suitable" ... be prepared to trim to suit
04-10-2020, 11:15 PM   #3
QuoteOriginally posted by kypfer Quote
Much obliged, thank you.
04-11-2020, 03:59 AM   #4
amateur dirt farmer
pepperberry farm's Avatar
used ones on eBay are running about $25 to 40...
04-11-2020, 04:12 AM - 1 Like   #5
D1N0's Avatar
Silly pricing for a piece of plastic.
04-11-2020, 05:36 AM - 1 Like   #6
roberrl's Avatar
I note in the title of this post the word "bayonet" - generic 72mm hoods are threaded not bayonet.
JJC offer many compatible copies of Pentax hoods but I don't know about the 16-85.
The original will have a Pentax code on it such as RBC xxxxx.
An e-bay search on that code will quickly show if a bayonet hood is available.
If not as others say any 72mm threaded hood will fit but may give vignetting at the wide end of the zoom range.
04-11-2020, 06:48 AM   #7
ramseybuckeye's Avatar
A quick search on ebay for PH-RBA 72 shows no generic, but brand new ones can be had for 43.01US shipped. It shows some used ones designated for the FA28-200, don't know if those would line up right, possibly?
04-11-2020, 07:56 AM   #8
Otis Memorial Pentaxian
Adorama has the PH-RBA 72 for $28.95 USD. That seems like a fair enough price to me.
https://www.adorama.com/ipxphrba72lh.html?
It is hard to say what the price for same in Australia might be. The problem with knock-offs is poor fit and risk of vignette since they are usually not a good clone.
04-11-2020, 07:26 PM - 1 Like   #9
Thanks for all the suggestions.
Aussie dollar is close an all-time low. Which means over $70 for a genuine part. (Can't see the value.)
I'll try an el cheapo and surgery.
PS the Pentax 16-85 lens rocks
PENTAX K-5  Photo
04-23-2020, 08:06 PM   #10
SOLUTION
- EW78D lens bayonet for Canon on eBay, obviously not made by Canon as the price was very low.
- Fits almost perfectly, a little loose, so I've added a 3-4mm wide band of gaffer tape around the small clip inside to increase the resistance against the lens . Took 60 seconds.
- Some interference with field of view at 16mm-24mm end, so I will have to trim ends off.
See attached photos in case you're not sure what I mean.
IPhone 6s Plus  Photo
bayonet lens hood, brand of bayonet, hood, k-mount, lens, pentax, pentax lens, slr lens
72mm CPL recommendation for 16-85mm? flyingfishfinger Pentax SLR Lens Discussion 13 09-19-2018 07:28 AM
Sigma 8- 16 mm lens correction / metadata in PS & LR - especially at 8 mm beholder3 Post-Processing Articles 45 06-20-2014 10:23 AM
When is a Pentax bayonet not a Pentax bayonet albrechtnamatdurer Pentax SLR Lens Discussion 6 06-28-2009 09:35 PM
Bayonet lens hood for Sigma 28-200 w 72mm filter diameter? Sodbuster Pentax SLR Lens Discussion 0 03-16-2009 09:43 AM
All times are GMT -7. The time now is 08:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
