Originally posted by jgnfld I have tested my 55-300 PLM with and without the 1.4x teleconverter on a K-70 and cannot detect any increase in resolution in distant targets including smaller text on oil tanks 2 km away at 300mm. Images are smaller FOV, of course, but contain no perceptible additional detail. That is with now 2 55-300s (dropped one that bounced and rolled down a slope splitting into two parts. VERY sad.) so I don't think it's an individual lens issue.
Understanding folks saying a TC doesn't ad more detail. - PentaxForums.com
Sorry the images are gone, thanks Photobucket. Hopefully you get the gist without the photos.
My method was find something with print in various sizes. Back the tripod out until the the lens in question can no longer resolve the small print. From the same spot, put the TC on and see if the TC resolves what the lens alone couldn't. I'm guessing you'll be surprised. If there is one thing people need to understand , its' that not all the resolution available from the lens is needed for every images. IN fact, what I've found is, in many images you get pretty much the same images from 16 MP and 36 MP sensors. But every now and then an image comes along that can actually use the extra resolution.
For the most part, my guess is higher resolution is optimal at most 5% of my shooting. YMMV.
I really have to go find those pictures and repost them.
To my mind, the worst assumption commonly made by people on the forum is that better lenses get you better image in every circumstance. It leads to a lot of heartbreak when people break the bank for an expensive piece of glass, and it doesn't change their photography much.
AN update of the TC post..
My first series of images went as follows... taken at about 40 feet, with not a lot of detail in the test subject.
DA*200
DA*200 plus 1.4
DA*200 plus 1.7
DA*200 by itself enlarged to the same size as the DA*200 2.8 plus 1.7x AF Adapter
Both TC's are clearly better than the DA*200 image on it's own.
