04-22-2020, 11:59 PM   #1
Dust inside WR lens
Iím looking at a second hand WR lens. Iíve only ever had A and M series lenses before. In the description there is the following message ď There is an extremely minor amount of dust within the lens.Ē.
Now dust inside a lens normally really doesnít bother me in the slightest. However Iím wondering as it is a WR lens this may be something to be concerned about or not in that some of the sealing may be slightly failing. I know it is weather resistant and not weather proof but I thought Iíd ask the learned group before exploring this lens further. Unfortunately Iím unable to view the lens before I buy due to the current Coronavirus measures. However I am able to return it if Iím not satisfied.
So thoughts? Dust inside a WR lens no problem at all or a potential risk?
04-23-2020, 12:14 AM   #2
chrism888's Avatar
I wouldn't consider it a problem as its described as minor and as you say, you've the option to return if not satisfied
04-23-2020, 12:40 AM   #3
Thanks. I was just wondering if dust inside is a sign of the weather seals failing prematurely rather than the affect itíll have on the pictures if that makes sense. If it wasnít a WR one I wouldnít be remotely worried but I know nothing of modern WR lenses so just checking if itís something to worry about or if completely normal. I waffle on without getting to what I actually mean sometimes ��
04-23-2020, 12:55 AM   #4
chrism888's Avatar
The action of a zoom lens will always push and pull air through the lens, so will accumulate a little dust, nothing to worry about imho, I've lenses that are over 20 years old, they show signs of use and some dust, but nothing shows up on the images
04-23-2020, 12:58 AM   #5
BigMackCam's Avatar
WR isn't total weather sealing... it's just a number of design precautions that significantly reduce (but don't totally eliminate) the likelihood of moisture and dust ingress in light-to-moderate conditions. Especially in zoom lenses without internal focusing, air still gets drawn into the lens, and some dust will get past the WR measures. It's no more of a concern than with any other lens, and doesn't suggest there's anything wrong with the WR aspects of the lens.
04-23-2020, 12:58 AM   #6
Ok brill thanks.
04-23-2020, 01:39 AM   #7
HYS
It happens. But seldom.
04-23-2020, 01:58 AM   #8
Paul the Sunman's Avatar
The AW on some of the modern high-end lenses should be more secure, especially primes, and zooms that both focus and zoom internally (DA* 70-200).
04-23-2020, 03:14 AM   #9
D1N0's Avatar
A lens isn't WR inside of the mount, so it will draw in dust from inside the camera body. Can also happen when the lens is handled off camera.
04-23-2020, 04:26 AM   #10
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Paul the Sunman Quote
WR: Lenses with the WR designation are weather resistant. They are sealed so that they better withstand use in light rain and blowing dust.
AW, WR: Lenses with the AW (All Weather) or WR (Weather Resistant) designations are sealed so that they better withstand use in light rain and blowing dust. AW is the more resistant of the two.
Pentax K-Mount Lenses Explained: The differences between various Pentax lens series
04-23-2020, 04:36 AM   #11
Lowell Goudge's Avatar
QuoteOriginally posted by chrism888 Quote
Donít know the lens but many lenses now with internal focus and zoom donít change volume during either process. That makes them easier to make WR.
Dust is more likely due to what happens when changing lenses, open lens, open camera body, no caps.
It will happen no matter how much care you take
04-23-2020, 09:51 AM   #12
My 55-300 WR RE has lots of dust behind front element. Still, the barrels seem to fit very snugly within each other so the seals seem tight. Looking closely around the front element, the edges look open to the inside, to me. It's possible that I can't see the seal. Even with the dust, that lens is optically VERY much better than it's price indicates. It's a sharp piece of kit.
04-23-2020, 03:36 PM   #13
As mentioned before, if the lens extends and retracts while zooming in and out it must either breath air in or exhaust air out.
04-23-2020, 03:53 PM   #14
Even brand new off the shelf, there are a few dust particles visible inside a never used lens.
"Minor amount of dust" is basically a standard disclaimer, because dust is always present, yet some buyer may demand a return based on "dust" on a newish or "mint" lens.
dust, dust inside wr, k-mount, lens, pentax lens, slr lens, weather, wr
Dust inside FA 24 and FA 85 TerryL Pentax SLR Lens Discussion 6 07-16-2019 03:21 PM
Dust or air bubbles inside lens (with picture) Tomm Pentax SLR Lens Discussion 19 05-02-2012 04:59 PM
Blowing dust. Will I get more dust inside ? alphalt Pentax DSLR Discussion 7 05-12-2010 10:09 PM
Cleaning the dust inside the lens rustynail925 Pentax SLR Lens Discussion 10 01-10-2010 08:37 PM
Little Dust Inside Prime Lens?? rdrum76 Pentax SLR Lens Discussion 11 01-11-2009 10:42 PM
All times are GMT -7. The time now is 05:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
