Originally posted by UncleVanya My history with sdm lenses is extensive. Failing sdm can do weird things. If you could post more details maybe I could try my lens and others could too, and we could compile the times but we would need some standard testing to make it meaningful.
Thanks for the offer. Before going into details, the behaviour was so vastly different by focal length that I don't think you need to be very scientific:
1) focus on a distant near infinity object (I live downtown in a large city, so I just pointed to another building in the distance)
2) focus on a nearby object (e.g. my balcony or something inside)
3) focus on a distant object again
4) focus on nearby object again
I performed this on my K-01 (live view only), in good daytime light in single (not continuous) AF (multi point) at 60, 85, 135, 200, and 250mm. At 60/85/135mm, the times were pretty constant and pretty short. At 200/250mm, the time is at least 2-3x as long, and the way the lens focuses seems different. You can see the focusing slowly gliding towards the right distance (the SDM makes a steady very quiet whine), while at shorter focal lengths it tends to "snap" a few times to quickly converge to the right distance (the SDM makes a series of quiet squeaks).
The lens ultimately manages to lock focus. The slowness is most obvious when the lens hunts, which might be more likely at longer focal lengths. For small changes in focus, 200/250mm seem to behave no different than 60/85/135mm.
If a video helps, let me know, but the difference was not subtle at all.
I then did the same thing on my K-1 II in live view, and the behaviour was almost identical.
I then switched to OVF (phase detect AF), and there was hardly any variability in AF time at various focal lengths; the SDM behaves by "snapping" to the right focus with progressively smaller corrections (series of quiet squeaks). So the slowness is unique to longer focal lengths using contrast detect (live view) and most noticeable when the distance changes a lot (e.g. hunting / MFD-infinity / infinity-MFD)
The other SDM lenses I have are the DA*55, DA*50-135, and DA*300. The prime lenses seem to behave fine, but obviously don't zoom. The 50-135 does not slow down much on the long end.
I would summarize the "problem" as very slow hunting at 200/250mm in live view only. So maybe it's just by design and I never noticed it before.
