Originally posted by motorhead9999
Hello all,
I shoot with a full spectrum infrared modified Sony mirrorless camera. For those who aren't aware, most modern lenses cause hot spotting on images (basically a very concentrated circle of brightness in the center of your image, making it mostly unusable) and so I have to resort to vintage lenses most of the time. I use a vintage Pentax K 28mm f3.5 with excellent results. I'm trying to see if I can assemble a good infrared kit from mostly pentax glass, but one of the keys is i need a 52mm filter thread (to try and share my filters among only one size). Obviously I have the 28mm, and I'm looking for a 20ish, a 50 or 55mm, and a 135mm.
Has anyone used any primes in those focal lengths with that filter thread diameter? Obviously I had good luck with the K series, but I don't know much about the M or A series lenses. Looking for something comparable (or better) in image quality to Olympus OM lenses
TIA!
Many, if not most of the M series lenses are 49mm filter threads, so a stepping ring would be your friend, and most of the common lenses that aren't 49mm are 52mm. You should be able to get the focal lengths you need from the M series.
Pentax is pretty well known for making excellent 50mm lenses. The old K series 50/1.4 is very good indeed (I own three of them, all are excellent), and there is a rather overlooked gem, the M150mm f/3.5 which might answer your need for something in the 135mm range. The K50/1.4 uses a 52mm filter, the M150/3.5 uses a 49mm filter.
I can't speak to the quality of the lens, but the M20/4 is about the only thing Pentax has made in that focal length with a small front filter. My understanding is they are rare as frogs hair.
The K and A series 24/2.8 share the same optical formula. I have the A series, and have found it to be very good, and it uses a 52mm front filter.
