04-30-2020, 01:48 PM   #1
Pentax SMCP-DA* 300mm f/4 ED (IF) SDM
hi i was looking at this
Pentax SMCP-DA* 300mm f/4 ED (IF) SDM lens on the B&H site, the have a disclamer that it is not campatable with full frame, want to use with my k1. according to your campatability chart and it is. also listed as ff in the lens review. SMC Pentax-DA* 300mm F4 ED [IF] SDM
so will it work for the k1 ?? this is the reply i got from b &H
Thank you for contacting the Sales Department at B&H Photo Video and Pro Audio.
The rear element is the size of a cropped sensor not a full frame. It will work fine with the K20 not the K1
thanks for any help
04-30-2020, 02:00 PM   #2
ehrwien's Avatar
DA lenses are usually, per name, lenses made especially for crop sensor cameras, but this one, along with a few others, has been declared fullframe compatible by Ricoh themselves. So you can use this lens without any limitations on a K-1.
Other lenses that are also DA lenses, but officially fullframe compatible, include the SMC Pentax-DA* 200mm F2.8 ED [IF] SDM and HD Pentax-DA 560mm F5.6 ED AW
04-30-2020, 02:29 PM   #3
jatrax's Avatar
Works just fine on the K-1. It is one of the few DA lenses officially designated as FF compatible by Ricoh.
04-30-2020, 03:59 PM   #4
hcc
hcc's Avatar
The lens is closely based upon the older FA*300mm f4.5 which is a FF lens. Although I use K-7/K4 APS-C camera bodies, I personally bought the FA*300mm f4.5 instead of the DA*300 f4 because of the weight. The FA*300mm f4.5 is smaller and there are little difference in IQ IMHO.
If you have any doubt on the DA*300mm f4, consider to purchase 2nd hand a good quality FA*300 f4.5 from a reliable supplied (eg Keh.com, Adorama Used, B&H used).
My 5 cents... hoping that it may help.
04-30-2020, 06:32 PM - 3 Likes   #5
Billk's Avatar
It is magical on full frame. Really beautiful IQ. You don't lose much when you use it with the 1.4X teleconverter either, although obviously that means going to crop frame.
04-30-2020, 08:54 PM - 2 Likes   #6
Tas
I concur with the above. This is a great lens and it goes well on the K-1.
Tas
04-30-2020, 09:47 PM   #7
pschlute's Avatar
QuoteOriginally posted by retired2007 Quote
It is fully compatible on FF. On the K1, Pentax have two sets of lens correction available for this lens, one for FF and one for crop.
04-30-2020, 10:07 PM   #8
Some lenses with DA designation cover full frame. DA is not designed for FF, Pentax was just under pressure to tell us that some tele designs cover FF - otherwise no fixed focal length telegenstes would exist for FF. There isomer work to do here by Pentax. In this forum many members are happy to see that some DA glass covers FF, read the fine print carefully and you will know what to expect.
05-01-2020, 06:21 AM   #9
QuoteOriginally posted by Tas Quote
Tas
Fantastic shot!
05-01-2020, 03:18 PM   #10
Tas
QuoteOriginally posted by vkaro45 Quote
Fantastic shot!
Cheers mate.
Click on the image and see it larger on Flickr to check out the left rear suspension coil.
Tas
05-01-2020, 06:40 PM   #11
Completely missed that. That could have went bad quickly!
300mm, f/4, frame, k-mount, k1, lens, pentax, pentax lens, pentax smcp-da* 300mm, reviews, sdm, slr lens, smcp-da* 300mm f/4
For Sale - Sold: Pentax SMCP-DA 300MM F4 ED (IF) SDM $840 Aboudd Sold Items 4 05-03-2015 05:53 AM
SMC Pentax-DA 55-300mm F4-5.8 ED vs SMC Pentax-DA* 300mm F4 ED [IF] SDM Budster48 Pentax SLR Lens Discussion 12 06-30-2013 11:00 AM
For Sale - Sold: SMCP Pentax-DA 15mm F/4 ED AL Limited and SMCP Pentax-DA 70mm f/2.4 Limited Lenses Yosemite Sold Items 3 04-02-2013 05:29 PM
Pentax 300mm f/4 SMCP-DA* ED IF SDM AF: Lens Test Clicker Pentax SLR Lens Discussion 3 09-20-2008 08:58 AM
All times are GMT -7. The time now is 06:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
