05-02-2020, 11:22 AM   #1
Pigeon's Avatar
Pentax SMCP-DA* 300mm f/4 ED (IF) SDM - teleconverter or new camera
Currently I use K-5 and DA 300, mostly for birding. Wonder what will be best way for improvement, get new camera, like Kp or find teleconverter. Could you advise which teleconverter will provide best results?
05-02-2020, 11:46 AM - 2 Likes   #2
baro-nite's Avatar
The HD Pentax-DA 1.4x AW AF Rear Converter plus DA* 300 on the K-5 is a good match. Here are some of my photos with that combination.
As always, the real key to improvement with bird photography is finding ways or locations where you can get closer to the birds.
05-02-2020, 11:51 AM   #3
pschlute's Avatar
Pentax KP + DA 560 ?
05-02-2020, 12:13 PM   #4
Seeker of Knowledge
aslyfox's Avatar
consider a K 3 or K 3 II
Pentax K-5 vs. Pentax KP vs. Pentax K-3 vs. Pentax K-3 II - Pentax Camera Comparison - PentaxForums.com
__________________
you could also consider renting equipment to see what you actually like
https://www.pentaxforums.com/forums/137-photographic-industry-professionals/...ml#post4542890
_______________________
LensRental is running some specials
check this section
https://www.pentaxforums.com/forums/94-pentax-price-watch/
05-02-2020, 12:38 PM   #5
Pigeon's Avatar
No, it is too expensive and heavy. Generally I don't use tripod, except my backyard.
---------- Post added 05-02-2020 at 02:55 PM ----------
QuoteOriginally posted by aslyfox Quote
__________________
Information on Businesses that offer cameras and lenses for rent - Page 3 - PentaxForums.com
Thank you, good idea to get converter for week and try.
Why K3 would be better? I see only three advantages - longer shutter life, bigger LCD and battery. KP is more new. What is wrong with it?
check this section
Pentax Price Watch - PentaxForums.com
check this section
05-02-2020, 01:10 PM   #6
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Pigeon Quote
. . . Why K3 would be better? I see only three advantages - longer shutter life, bigger LCD and battery. KP is more new. What is wrong with it?
check this section
I prefer the K 3 and K 3 II over the KP
[ I only have a KP because I was lucky enough to win a contest here at the forum via random luck drawing ]
The K 3 would probably be cheaper on the used equipment market
two slots set one for raw the other for jpeg or as a back up
better burst rate, personal preference
05-02-2020, 04:44 PM   #7
I use the pentax 1.4x rear converter with the da300 on a k3. I use a tripod with a wimberlay sidekick gimbal with it.
05-02-2020, 05:06 PM   #8
I use the DA* 300mm with a 1.4X teleconverter on a K70. I find it to be well balanced and comfortable to use hand held. I like to use it on a tripod when practical. Often times it's not.
05-02-2020, 06:53 PM   #9
Theov39's Avatar
I can't advise if a new camera would b a good option, but I found the Kenko Pz-AF 1.5X Teleplus SHQ to be a great TC with the DA*300 on my K-3. The auto focus becomes a bit slow but the image quality is great. Mind you, I am just shooting stationary objects, not wildlife using the TC so YMMV.
If you go down that road, it is important to get the SHQ version of the TC and not the earlier DG version as the DG version doesn't seem to work with * lenses.
Kenko (?Promaster et al..) AF/Pz-AF 1.4x/1.5x Teleplus.... Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
Despite being labled 1.4X, instead of 1.5X, the Tamron is allegely the same rebranded TC if you can't find the Kenko version:
Tamron-F 1.4X Pz-AF MC4 Lens Reviews - Miscellaneous Lenses - Pentax Lens Review Database
05-02-2020, 07:07 PM - 1 Like   #10
ramseybuckeye's Avatar
check this section
Nothing wrong with a KP, the KP has better stabilization and low light abilities than the K-3 series, both pretty useful for long lens shooting.
05-02-2020, 07:51 PM - 1 Like   #11
UncleVanya's Avatar
If the choice is KP vs 1.4x TC I'd say get the KP. The KP will have 1.5x pixels on the subject and better autofocus and will give you this on all lenses without any loss of light. The 1.4x will work on the KP in the future adding additional gains but by itself it will not be as versatile. The as yet to be released flagship level apsc camera might be better still but eventually isn't now.
05-02-2020, 10:28 PM - 1 Like   #12
Where do you need improvement? Resolution, magnification, speed,... if you know the question, the answer is right there. If the lens is set, the camera can improve speed and resolution to a certain extent. Magnification requires an additional lens, the TC or practice. K3 is a significant improvement over K5, faster and more precise AF. I assume KP has even better precision comparable to K1.
Pentax only offer one converter. I did not like it with K3 and da300, focus speed and precision did not cut it, probably better with KP or in light flooded areas.
05-03-2020, 01:18 AM   #13
I "upgraded" from a K-5 to a K70, for the 50% higher resolution to enable tighter cropping, then to a KP for the improved auto-focus performance, especially on flying birds. In my mind both reasons were justified.
Initially I was using a Sigma 70-200mm f/2.8 + matching 2x, leftovers from my film days, these days my "goto birding lens" is my Sigma 150-500mm.
Most of the time that's a perfectly adequate setup and light enough, (approx. 2.5kg), to be used hand-held as a carry-about configuration for an hour or two at a time. In a more stationary environment, in a hide, for example, or just sat quietly concealed with a tripod, the lens/camera combination will work adequately with a Kenco 1.5x teleconverter on a stationary subject in good light.
Inevitably, personal preferences will play a part and "your mileage WILL vary"
Good luck!
05-03-2020, 07:08 AM   #14
Pigeon's Avatar
Thank you for answers. Currently plan is try TC and probably waiting K-new. I just afraid this waiting could be pretty long.
battery, camera, ii, k-3, k-mount, kp, lcd, life, pentax, pentax lens, pentax smcp-da* 300mm, section, slr lens, smcp-da* 300mm f/4, teleconverter, vs
Pentax SMCP-DA* 300mm f/4 ED (IF) SDM retired2007 Pentax SLR Lens Discussion 10 05-01-2020 06:40 PM
For Sale - Sold: Pentax SMCP-DA 300MM F4 ED (IF) SDM $840 Aboudd Sold Items 4 05-03-2015 05:53 AM
SMC Pentax-DA 55-300mm F4-5.8 ED vs SMC Pentax-DA* 300mm F4 ED [IF] SDM Budster48 Pentax SLR Lens Discussion 12 06-30-2013 11:00 AM
Pentax 300mm f/4 SMCP-DA* ED IF SDM AF: Lens Test Clicker Pentax SLR Lens Discussion 3 09-20-2008 08:58 AM
All times are GMT -7. The time now is 09:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
