Originally posted by house doesn't this just mean that the dfa has more fringing capacity than many lenses? Just that some dont trigger it whilst others do? Do you have other modern glass that reacts like that to astro.
Most of what I own lens wise is old. I own only 4 auto focus prime lenses and of those only 1 was a digital era design. As far as my modern (auto focus) prime lenses go:
I haven't used the FA 77 ltd for astro so I dont' know how it performs I probably should but haven't figured out a good target to try it on.
The DA 35mm f/2.4 is barely acceptable wide open but if you run it at f/4 it is pretty good
The DFA 100/2.8 macro needs to be stopped down so much that that it becomes pointless for doing astro because running it at f/8 is dumb
The Sigma 300mm f/4 APO Macro (film era lens with the awful zen barrel coating) this lens is great good enough wide open and great at f/5.6
As far as my other lenses and astro:
S-M-C 17mm f/4 Fisheye takumar - A hot mess for astro don't bother. It is slow and needs to be stopped down to near f/11 to not suck for astro, so it sucks for astro
S-M-C 28mm f/3.5 Takumar - Not bad should be run at f/5.6 would be nice if it was faster
S-M-C 50mm f/1.4 Takumar - Run it at 2.8 for astro and it is golden
SMC A 50mm f/1.2 - useless wide open but gets good at f/1.8 and really good at f/2
Vivitar Series 1 135mm f/2.3 - purple fringes like mad even worse than the DFA 100/2.8 macro needs to be stopped down to at least f/8.
S-M-C 200mm f/4 Takumar - Acceptable wide open best if run at f/5.6, this and the K or M version are some of the more sought after starter astro lenses for good reason
S-M-C 300mm f/4 Takumar - Needs more stopping down than the 200/4 and has purple fringing but it isn't too bad
SMC A* 400 f/2.8 ED [IF] - Pretty good wide open with some light coma, stopped down to f/3.5 it is perfect
I have a couple of older zooms that I don't use much for astro but I have used my old Tokina 28-70mm f/2.8-4.3 at the wide end and it isn't bad at f/4 but does have some coma with really bright stars. I haven't used my SMC A 70-210 f/4 for astro so I can't speak to it. I also have my "cub scout" lens which I used when I need to cover almost my full focal length range with one lens so the Tamron 28-300mm F3.5-6.3 XR Di AF lens I own isn't one I have taken out for astro and don't plan on it.
