I use the Kenko Pz-AF 1.5x quite regularly with my Sigma 150-500mm which has an integral focus motor (no screw drive) on my KP. Autofocus is only really reliable in good light on a stationary subject, but that is with an f/6.3 lens, on an f/4 I'd anticipate no problem.
Two "negatives" to consider with this item :-
Firstly, the camera doesn't "know" it's fitted, so the EXIF always reports the native lens settings.
Secondly, as a result of the first issue, the in-camera shake-reduction doesn't fully compensate for the longer focal length.
Despite theses issues I consider the Kenko item to be good value for money and would recommend it to anyone prepared to work within these limitations.
There is also a Pz-AF 2x, with the same limitations as above, but would probably work in good light on an f/4 lens ... it's almost always m/f only on my f/6.3 except on a very stationary high-contrast subject.
Good luck
