If you look at the specs for the Pentax-F and FA 50mm f2.8 Macro, the minimum focus distance is 19cm, which gets you the 1:1 reproduction ratio. For the D FA it's 20cm. If your Sigma 50 can focus much closer than that, I wonder if you are getting more than 1:1. I own a Sigma 17-70mm f2.8 DC macro. While reading user reviews, one person commented that they could focus with the subject almost touching the front element. Don't know what focal length they were using for that result. Though I haven't kept records, the closest I get is probably 3-5 inches.
Originally posted by ChrisPMR When I was looking up other macro lenses I saw that the pentax 100mm macro has a minimum focusing distance of 30cm (12inches). I don't understand how it can be a macro lens if that's the closest focusing distance.
My Pentax-F 100mm f2.8 1:1 Macro focuses down to 31cm. The term 'Macro', when used properly, refers to a lens's ability to achieve 1:1 reproduction, regardless of what the minimum focus distance is.
