Originally posted by motorhead9999 how do the SMC Pentax lenses compare? For instance, how is an SMC 85mm f1.8 compared to a 90mm f2 Summicron from the same year?
A pre-asph 90mm 'cron Vs the K-85mm f/1.8 -
that would be a battle of the titans. I'd think apart form the differences in size and weight optical performance would be remarkably similar, the difference between f/2 and f/1.8 is largely academic. The Pentax lens would have an optical advantage over the Leica lens due to the use of SMC coatings giving it enhanced contrast, and the K 85mm f/1.8 can focus closer which is important for portraiture: Longer lenses are inherently problematic at close focus distances on RF cameras, particularly fast ones. Though having said that: the optical performance of a modern Leica apo-asph 90mm Summicron will comfortably beat the crap out of everything Pentax has made before the year 2010.
Originally posted by noelpolar the only person I'd listen to about such matters on this forum is Digitalis
I appreciate your confidence but surely, I'm not the only leicaphile here.
Originally posted by Lowell Goudge the customer picked the Pentax ones
Leicas optical design paradigm relies on simplified optical designs to prevent flare from becoming problematic. Advanced optical coatings allowed lens designers to literally throw that concept out the window and paved the way for zoom lenses and primes with element counts well into the double digits without problems arising from contrast destroying flare.
Originally posted by pinholecam ts basically an arms race between the German makers and the Japanese.
As I mentioned, improved optical coatings have a lot to do with this. Many manufacturers had something to prove to the world, particularly in post-war Japan when it came to competing with European manufacturers - the Japanese are very good business men and producing products that equal, if not exceed that of their German counterparts was their goal.
Originally posted by pinholecam The DSLR lenses also have a nearer minimum focus distance.The RF lenses are smaller though, superbly built and many bladed aperture.Then throw in the edge issues for RF lenses on digital and the analysis gets confusing again.
ahh yes the Achilles heel of the RF - closer focusing, an inherent advantage with the SLR is that you can see the focus errors coming. With an RF in the film days you were better off getting a ruler and manually calculating the focus distance*...with 35mm a small error can make a big difference.
Originally posted by pinholecam Don't forget that Leica means paying much higher prices and often for a slower lens.Example would be getting a Summicron 50/2 for the price of a A50/1.4 + K28/3.5
You can get Zeiss,Voigtlander,Canon,Nikon,Hexanon lenses second hand for modest prices and still get absurdly fast lenses...Voigtlander have the Nokton 35mm f/1.2 Nokton 50mm f/1.1 for modest prices compared to the Leica equivalents.
*With Live view capability on recent Leica M digital rangefinders macro photography is becoming more accessible for RF users, unfortunately the number of macro lenses made for M mount cameras can be counted on one hand.
