Originally posted by dirwood So I am trying to find a good lens for some bird photography. I am currently using a Sigma DG 70-300 1:4 - 5.6 on a K-r camera.
10 years ago, I was in exactly your position.
The store salesman, the same guy who sold me my Sigma 70-300 recommended the Sigma 70-200 2.8 with the 2x TC, I can't tell you how many times I've regretted not taking his advice. I have since purchased the DA*60-250, DA*200, DA 55-300 PLM, and an older Tamron 300 2.8 which I use with the HD DA 1.4 TC, F 1.7x AF adapter and Tamron 2x TC (7 element). I also tried out the Sigma 120-400 and found it no better in the long end than the 70-300.
I'd recommend an A-400 ƒ5.6. They can be had relatively cheaply, the IQ is not superlative, but still way ahead of the Sigma 70-300 or Sigma 120-400. It kept me busy until I had more money to fill out my line up.
The problem with TC's is they only take great images on great lenses. It's a double whammy, the lens has to be expensive, the TC has to be expensive.The lens has to out resolve the sensor by the same factor as the magnification. That being said, many good lenses will out resolve your K-r.
I seriously can't recommend anything under 400mm for birding.
On APS-c my preferred setup is the Tamron 300 with the 1.7x TC.
On the K-1 it's the Tamron 300 with the 2x TC.
510mm and 600mm respectively.
My only "final answer" recommendation in your situation would be maybe be a used K-70 and a DA 55-300 PLM.
The K-r resolution is fine, but it won't use the PLM lens and won't make maximum use of any of the current line up.. I've been using the DA 55-300 PLM with the 1.4 TC to get out to 420mm and it works fine, in excellent light. (But in low light under the canopy I can't even get it to focus sometimes.)
Pentax K-3 and DA 55-300 with 1.4 TC
Of course the 1.4 TC costs almost as much as the 55-300. But that gear will keep you happy for years, until you're willing to lay out the big bucks for some fast aperture lenses.
There is simply no cheap way to do this.
So, I'll just go back to an A-400 for your K-r. That will get you started. But you should probably look on it as a temporary solution. Especially with small birds that move quickly, MF is a serious disadvantage.
A-400 ƒ5.6 on a K-5, just to get you interested.
For birding on APS-c 400 (although I have many good images taken at 350mm with the 60-250 and TC) is the minimum, on an FF 600mm.
I have many bird images here
https://www.flickr.com/photos/149541448@N08/albums/72157683751426530/with/35777310235/ and here
https://www.flickr.com/photos/149541448@N08/albums/72157685465665753
Taken with all kinds of combinations, at least one taken with a K-x (almost the same as your K-r.)
K-x and DA*60-250
So you can get started with your K-r... but there isn't much that costs more in photography than birding.
And you won't be doing your best until you get to 500-600mm
My latest "lifer" captures, both taken with he Tamron 300 2.8 and 1.7 TC. in the last month.
SO good luck in your search, but in birding, you're looking down a money pit. Lenses that can operate with decent magnification and are sharp at distance are never cheap. Even the second hand ones start at around 3k.
One additional comment, the FA 300 4.5 has been recommended. We looked for one for years and never found one at a good enough price to make up for it being slower and not WR like the DA* 300. Usually on the forum and elsewhere, the DA*300 and HD DA 1.4 TC are the standard basic recommendation along with a 24MP sensor. And I personally would suggest not using a TC on a lens less than ƒ4. The DA 55-300 PLM being an exception based on it's light weight, but, you do have to have bright light to make it work.
