Originally posted by ChristianRock Ummm allow me to disagree with your findings
I was not aware that I had proposed findings.
Originally posted by ChristianRock if you consider that the 55mm is the longer lens, and reduce the size of the picture of the 30mm optical formula, you will see that all the glass elements of the Sigma are quite smaller and the lens is quite narrower.
This is a totally non-scientific scaling but it might give a better idea of what these lenses look like compared to each other, internally. Again, considering the Pentax 55 is the slightly longer lens.
Indeed, respectfully it's non-scientific. You can't trust these lens drawings to be a perfectly accurate representation of the reality. An approximation, sure, not a reliable benchmark.
Originally posted by ChristianRock If they look like this internally, then why is the Sigma quite wider? Is their motor that much larger? I kind of doubt it.
Let's apply Occam's razor. You see the lens as being larger/heavier. It could be because the company pulled a "Beats audio" and artificially added useless elements to make it bigger / heavier. Or it could be because the designers did need that volume for the lens to deliver what they intended.
I have not opened any Art lens. I have not seen an actual, usable lens design ray tracing file. Or a STEP file rendering. Or whatever. I do know that guys like lensrentals, who regularly open up lenses, would have a field day of reporting dummy elements, wasted volume, or anything else on that line.
If the Art lens is that way, it's because the company didn't find a way to make it smaller.
