10-31-2008, 10:00 PM   #1
hahifuheho's Avatar
Quick-Shift Focus System on K200D
Hi!
I have a question about Quick-Shift Focus System on a K200D. When I compose a picture and AF doesn't satisfies me I use Quick-Shift Focus System and focus manually. However, when I fully depress the shutter button que camera just won't shoot (the focus indicador in the viewfinder keeps flashing, telling me it's not correctly focused). So far this has been frustrating and I've missed several shots because of it.
Does anyone know what is this due to?
Thank you.
11-01-2008, 12:40 AM   #2
tomtor's Avatar
You must first have a focus lock on something by pressing the shutter button halfway. Than you turn the focus ring (keep the button half pressed) to obtain the focus you really want and press the button fully...
11-01-2008, 02:14 AM   #3
sewebster's Avatar
Yep, it's lame. You can't take a photo with the camera in AF mode unless you are able to get an AF lock on something.
You can set your OK button to "cancel af" in the settings so that if this is happening you can just push the button to go to MF mode, but it isn't really that much better than flipping the front switch to MF.
11-01-2008, 02:30 AM   #4
works fine in af-s. its maybe something in the c-menu
11-01-2008, 03:28 AM   #5
tomtor's Avatar
QuoteOriginally posted by sewebster Quote
Edit: On a k10/k20:
As an alternative you can set the AF button to cancel AF.
Focus your lens and press the AF button with your dumb when pressing the shutter.
11-01-2008, 04:36 AM   #6
ftpaddict's Avatar
QuoteOriginally posted by ibbe Quote
Thinking the same thing...
11-01-2008, 09:07 AM   #7
Marc Sabatella's Avatar
Actually, I think it's *lots* better. Much easier and faster to find that OK button than the front switch, no danger of forgetting to flip it back, seems less likely to wear out the switch, etc. I keep my thumb kind of permanently poised by the OK button when using AF lenses.
11-02-2008, 06:15 PM   #8
Eigengrau's Avatar
I agree with the Ok-button AF technique. It will save you time, and you won't realize how much sense it makes until you try it. It probably allowed me to get 30-60 more shots than I would've gotten otherwise at a recent wedding.
It doesn't make you refocus every time you take your finger off the button, and you can actually keep focusing while you shoot a moving subject, or just focus once and leave it. You can make the decision on the fly.
11-02-2008, 08:41 PM   #9
sewebster's Avatar
I guess most of the time I have focussing issues I am using my FA50 (because I'm inside, not because the lens has problems) and since it isn't quick shift, it is only somewhat helpful to push the cancel AF button (since you can't actually MF until you throw the switch). But since this thread is about quick-shift, then yeah, I imagine the OK button would be significantly better.
To people mentioning the "AF button": the K200D doesn't have one.
focus, k-mount, k200d, pentax lens, quick-shift, slr lens, system
Quick Shift, for Canikon? systemA Non-Pentax Cameras: Canon, Nikon, etc. 7 01-27-2010 03:40 PM
Permanent quick-shift? LeDave Pentax DSLR Discussion 12 12-27-2009 12:41 PM
Kx DA L quick shift dilemma! Flopass Troubleshooting and Beginner Help 4 11-25-2009 01:06 PM
k-x with quick shift lense? p0opstlnksal0t Pentax DSLR Discussion 2 10-21-2009 04:08 AM
FA lenses don't quick shift focus? nostatic Pentax SLR Lens Discussion 7 03-15-2008 10:48 AM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, part of our network of photo forums!
