05-27-2020, 03:16 PM   #31
c.a.m's Avatar
QuoteOriginally posted by Bcrary3 Quote
Is there a way to calculate what the AoV would be from FF to APS-C?
Rather than plugging numbers into a formula, I usually refer to one of the handy-dandy online calculators: Depth of Field (DoF), Angle of View, and Equivalent Lens Calculator ? Points in Focus Photography
For a given lens focal length, the AOV on a full-frame camera will be 1.5 times wider than the AOV on an APS-C camera, which accounts for the so-called 'crop factor' between the two formats.
For example, at a FL of 210mm, the horizontal AOV would be:
  • Full frame: 9.8 degrees
  • APS-C: 6.5 degrees ( = 9.8/1.5)
- Craig
05-27-2020, 03:23 PM   #32
Bcrary3's Avatar
QuoteOriginally posted by c.a.m Quote
- Craig
So, if I am following correctly, the FA* 70-200 would have an AoV (on an APSC sensor camera) of 23 degrees to 8.4 degrees and the 50-135 would retain the same AoV of 31.5 to 11.9.
The 70-200 would appear approximately the same on the APSC as a 105-300 on FF if any of this makes sense. lol
Without having access to try either of them makes getting ready to shell out some $$ a much more involved process.
05-27-2020, 03:45 PM   #33
c.a.m's Avatar
Yes, I believe that's correct -- for a diagonal AOV.
Makes perfect sense when talking about the AOV. You've stated it clearly, I think.
Yeah, that's a challenge for many of us when few brick-and-mortar stores carry Pentax gear. I might suggest that the lens reviews here on Pentax Forums provide useful user reports, including comments on handling, size, weight, etc.
Personally, I was dissuaded from the DFA* 70-200 when I had a chance to handle it and a K-1 at a trade show a couple of years ago. I found that its weight and size exceeded my comfort threshold. On the other hand, there are plenty of users who don't mind the weight and are happy to carry it for the high optical quality. I guess I'm just a scrawny Canadian, despite having shoveled tons of snow over the years.
- Craig
05-27-2020, 04:18 PM - 1 Like   #34
Otis Memorial Pentaxian
clackers's Avatar
So my only thing with the FA 70-210 is that these are intended for the FF (AFAIK) which would effectively put the focal range around 105-315 that is the only thing, but I supposed that I could supplement that focal range with something else. (typically used the DA Limited 20-40, Sigma DG 50mm 1.4) Want to keep my kit as light as possible, also would prefer something a bit faster than f4 but gotta take what we can get lol.
I think you're a little confused here, Bcrary.
You say now you prefer faster than f4 but the DA*60-250 you were asking us about is f4!
And it does not matter if a lens was designed for FF, it will still work an APS-C, as the glorious FA Limiteds demonstrate.
And you say that the focal length range of the 70-210 is problematic but I read in one of your posts you're considering the FA*70-200.
I don't understand!
contender, da*, di, half, highly, k-mount, kmount, ld, pentax lens, rate, slr lens, sp, users
For Sale - Sold: K3 Bundle,DA 16-50,DA 50-135,DA 60-250,100mm macro JamesA Sold Items 4 06-19-2019 04:18 PM
Forget the DSLR vs Mirrorless battle here is the real battle Larrymc Canon, Nikon, Sony, and Other Camera Brands 20 03-11-2019 12:31 PM
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 25 12-30-2017 01:49 PM
Tamron 70-200 F2.8 vs Sigma 70-200 F2.8 EX DG HSM II - Battle of the older telephotos JinDesu Pentax Lens Articles 45 11-03-2014 06:30 AM
All times are GMT -7. The time now is 09:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
