05-22-2020, 07:30 PM   #31
SSGGeezer's Avatar
FA 50 f/2.8 on sale at usedphotopro.com as shown in the sale thread here. Reasonably priced, and sharp. The DFA 50 is more money. the FA is under 140 USD. Mine is a bit beat up but works great so as a budget model I can heartily recommend it.
05-22-2020, 07:42 PM - 1 Like   #32
Aa aslyfox suggests, a good used DFA 100mm f/2.8 macro non-WR might be had at a decent price, since it has been replaced by the better-built WR version, both being identical and very highly-rated optically. There might also be some advantage in the non-WR version having an aperture ring, for certain 35mm film bodies or other uses.
05-22-2020, 11:49 PM   #33
QuoteOriginally posted by AfterPentax Quote
To be honest, if you want very cheap: use the DA 18-55. In the manual of this lens they recommend(ed) to use it for macro and I did so quite often. It can focus 0.25m so you can get quite close to the subject. The 0.25mm works from 18-55 so you have a lot of combinations to make a good picture. The 0.25m is also quite close to the shortest focus distance of the several 50mm macro's Pentax produced. Give it a try. Contrary to the general thought of this lens it is better than you expect. It gives you time to decide if you really want to buy a (short) macro or not. The Pentax 18-55mm is probably the best kit-lens for APS-C on the market. Most of the time Macro lenses are not that cheap second hand, even the old manuals remain costly. So play with that kit-lens if you have it.
Great stuff afterpentax, some great advice there. Many thanks
05-23-2020, 06:38 AM   #34
UncleVanya's Avatar
Adding to what others said:
1:2 or 1:1 dedicated macro offers a lot of flexibility.
In cramped spaces a mock macro zoom might give the best results if 1:3 or 1:4 is sufficient.
Raynox, Nikon and Canon all make excellent APO close up lenses. Many macro sites have concluded that on longer lenses these outperform tubes by a lot. Even on shorter lenses if high magnification isn't required they excel. Remember there is no loss of f stop using these vs tubes.
A combination of zoom and Close Up Lens (filter attached) can also work as it offers more flexible positioning than a fixed focal length lens plus close up lens. However test to ensure no vignetting occurs.
05-23-2020, 06:58 AM - 1 Like   #35
Wasp's Avatar
I have not heard of Raynox before, so I looked it up.
05-23-2020, 07:03 AM   #36
ramseybuckeye's Avatar
I have a sigma 50/2.8 (manual focus with an A setting) on the way, I paid $54 including shipping. I know it is a very good lens because I already have one. My other is not in the best shape so I have kept watching. The autofocus Tamron 90 used lens are going for $125-175 these days. I picked up one of those a while back. Strangely I don’t shoot that much macro, but I like to have the ability, and do it as well as I can.
The thing about macro for me is that I will shoot macro on a tripod, therefore autofocus is not needed. On the tripod I can use live view, focus peaking, and magnification to get superb focus.
Another inexpensive alternative is the Pentax-F 35-70, although it’s not really a macro at 70mm you push the zoom to macro and becomes close focusing (I assume that’s how it works). It’s a nice lens overall and can be bought very cheaply.
05-23-2020, 07:31 AM   #37
Seeker of Knowledge
aslyfox's Avatar
from what I have read and with my experience with my D FA 100mm F2.8 Macro
dedicated macro lenses are very good and useful, even when not used as a macro lens
05-23-2020, 10:25 AM   #38
QuoteOriginally posted by ramseybuckeye Quote
I like my F 35-70mm very much for hiking and mountaineering and the close focus ability is also useful and provides sharp images, but it's only a 1:4 magnification so not even close to the possibilities a real macro lens provides. If I am not mistaken even my 18-55mm kit lens can go closer.
05-23-2020, 03:06 PM   #39
The 18-55mm has a minimum focus of about 10" (0.25m), but it is only f/5.6 at the long end. With the OP's original requirement of good subject separation, a rather wider aperture seems more desirable. Having said that, If the OP has an 18-55mm to hand and he's happy with the results ... problem sorted
05-25-2020, 07:17 AM - 1 Like   #40
UncleVanya's Avatar
Add this to the 135 and shorter lenses you already have and get closer...
Pentax Helicod Extenstion Tube K - PentaxForums.com
05-25-2020, 07:25 AM   #41
UncleVanya's Avatar
Another option:
SMC PENTAX-M MACRO 1:4 100mm - PentaxForums.com
05-25-2020, 03:13 PM   #42
MossyRocks's Avatar
Add this to the 135 and shorter lenses you already have and get closer...Pentax Helicod Extenstion Tube K - PentaxForums.com
Don't tempt me. I've bought enough new stuff in the past 2 weeks and that looks nicer than my off brand M42 one.
05-25-2020, 03:33 PM - 1 Like   #43
Seeker of Knowledge
aslyfox's Avatar
what makes you think we would tempt anyone to spend their money
good luck
and we are sure you will choose wisely
05-25-2020, 04:05 PM   #44
MossyRocks's Avatar
QuoteOriginally posted by aslyfox Quote
good luck
I've already spent just under $1000 and while I don't blame you (I did sort of turn down an offer) there is still just too much I want and the more I find out exists the more I want.
05-31-2020, 04:56 AM   #45
I have the Cosina 100 f3.5, only relabeled as a Pentax FA
It works really well but makes a horrible racket when focusing.
The matched multiplier is cool, but 1:2 is good for me most of the time.
I’ve also tried the Raynox, with very good results on a 200mm lens in particular...
And I have a Takumar 50mm f4 (1:2 but very sharp) and a FA50mm f2.8 (1:1 and easier to use)
I’ve found for my sort of casual macro, I want a lens with ‘A’ contacts to enable p-ttl flash. Most extension tubes don’t do that.
If I was starting from scratch, I’d probably start with the Raynox then an A50mm macro.
-Eric
budget macro lens, camera, dslr, lens, macro, photography
Yet another lens advice request: Wide prime or zoom or ? on a budget mgvh Pentax SLR Lens Discussion 43 08-06-2014 09:03 AM
best budget macro lens ? t.manning Pentax K-30 & K-50 31 03-04-2014 07:45 AM
Advice about my first lens for new K-5 IIs only $200 left in my budget yas_min Troubleshooting and Beginner Help 24 02-01-2014 08:48 AM
Expensive primes vs. budget zooms…personal experiences and advice utak Pentax SLR Lens Discussion 48 05-06-2013 07:00 PM
Need some lens advice - Tight Budget fvalduga Pentax SLR Lens Discussion 8 02-28-2009 08:43 AM
All times are GMT -7. The time now is 07:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
