11-01-2008, 04:38 PM   #1
depth of field
using a 50mm lens for example
is the depth of field for a 50mm or 75mm field of view
Dave
11-01-2008, 04:48 PM   #2
Perhaps this chart will help you. It is easy to use and you can plug in many variables and calculate the DOF.
Online Depth of Field Calculator
11-02-2008, 07:20 AM   #3
Lowell Goudge's Avatar
it's too bad the calculator does not also correct for print size.
the whole issue of depth of field and the "circle of confusion" is absolutely dependant on the final print size.
FYI assume this is for 8 x 10 prints, and since it appears you can enter a circle of confusion, ig you want a 16 x 20 enter 0.01 not 0.02mm it scales linearly.
11-05-2008, 11:14 AM   #4
Miserere's Avatar
QuoteOriginally posted by dafiryde Quote
Dave
The DoF will be that of a 50mm lens...on an APS-C sized imaging medium. I know that's not the answer you wanted, but that's how it is.
For the same FoV (meaning what you would see through a digital Pentax viewfinder with a 50mm lens or a film viewfinder with a 75mm lens) the digital camera will have a DoF that is approximately 1.5 times deeper than the film camera.
11-05-2008, 01:21 PM   #5
sewebster's Avatar
This calculator uses print size:
A Flexible Depth of Field Calculator
50mm, depth, field, k-mount, pentax lens, slr lens
Depth of Field Calculator barbosas Photography Articles 19 02-11-2010 12:09 PM
depth of field miss_alexx Troubleshooting and Beginner Help 20 12-11-2009 10:56 PM
depth of field rattrap Troubleshooting and Beginner Help 9 10-28-2009 11:20 PM
calculating the depth of field rustynail925 Troubleshooting and Beginner Help 18 10-06-2009 05:31 AM
Depth of Field Table? naturalog Photographic Technique 6 05-20-2008 11:59 AM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
