Originally posted by basrietkerk Thanks again and I will try to blast you away with some excelent tele-photography over the coming months.
Congratulations Bas. I hope you will share your images and experiences in the long lenses thread:
300mm plus Lens Club: discuss your long lenses - PentaxForums.com
One word about the Sigma long lenses: they are known to be fussy about which teleconverters will work on which lens. I suggest you do some research about this.
As a post script to this discussion, I would add that I have been through the rounds of xx-300 consumer zoom (DA-L 55-300, DA 55-300 PLM), 300mm prime (FA*300 f4.5), xx-500mm zoom (Sigma 170-500) and long prime (Sigma 400mm f5.6 tele macro), and have tried a teleconverter with each. There is no perfect solution; everything is a compromise. The more so in K-mount, because the telephoto lens options (particularly for fast-focusing long lenses) are limited compared to other mounts. On the plus side, though, there are good affordable options - and a wealth of help and experience available here.
Of the lenses I have used the best optical quality comes from the FA*300 (although it is slow to focus, so not great for birds in flight). My most-used lens is the DA 55-300 PLM, for its very good image quality, light weight, versatility and fast AF. 300mm gets you reasonable coverage of small-medium sized birds within say 10m and heavily cropped images of anything beyond that. The bigger gun of a 400mm prime adds a lot of weight and bulk (about 1.3kg); the xx-500 even more so (about 2kg). As the distances to subject increase, so does the degree of difficulty - by the time I get to, say, wading birds at 40m, atmospheric conditions and subject size in the frame (even with the 400mm prime or 420mm of 300 + TC) will usually limit the shot to just a record of the observation. And long lenses eat light. I agree with what others have said, that the key to improving bird photography is to try to get closer to the birds and to observe and understand their behaviour.
The other thing I would add is that a flash with an extender can be a valuable addition, bringing out more colour and detail and allowing for some lower ISO/faster shutter/narrower aperture. Just limit the fill to one stop or so. And consider a cheap gel to ensure a more suitable colour temperature for the flash beam.
