Originally posted by brbob1 There are several of these big lenses listed on eBay that state "missing rear mount". My question is this. Are the rear mounts on Pentax lenses interchangeable? would a mount off off a cheap 50mm f2 fit on the big 500mm lens. Either the K bayonet mounts or the older M42 mounts.
Sounds too good to be true but I thought I would ask.
I haven’t looked at the specific eBay sales you reference, but take care what you bid on. The Takumar and SMC 500/4.5 and 1000/8 have a
Mount Tube that is removed to screw a standard filter into the optical path at the rear end of the lens. Over time many of these mount tubes have been modified* to fit cameras other than K-mount, such that people buy a good lens copy with a “foreign modified” terminus, find a lesser copy with a proper K-Mount, scavenge the mount tube and sell the lesser lens sans mount tube. The lens is ABSOLUTELY USELESS without the Mount Tube.
Be certain the selller includes mount tube, and be certain the mount tube is K-mount terminated.
* Around 1970 the Associated Press converted from Pentax to Nikon as their standard reportage body. Apparently one of their lens technicians converted the mount tubes for a couple dozen Takumar 500/4.5’s to a Nikon bayonet terminus using a T-Mount threaded joinery and a T > F Nikon converter. At one time I owned one of those lenses and was able to convert it back using a Vivitar T > K converter.
