Originally posted by bertwert I personally found the 18-135 an improvement to the 18-55. Being WR, it's also convenient 'all-in-one' lens for wet conditions.As far as lighter weight - it's not much lighter (405g v 565g). If you want the lightest weight (not to mention better IQ), I'd suggest a pair of small primes (or trio, or just one), depending on your shooting style. Have a look through your images you shoot, and see what focal length you use most. For example, the combo of 21 Ltd + 40 Ltd is only 245g.
^ Good advice.
I see that the OP's profile lists a DA 21, DA 35 f2.4, DA 40 f2.8 and DA 50 f1.8. They are all compact, light weight and produce good images. The 21 and either the 40 or the 50 would be a good combination. For something wider you could consider the DA 15 Ltd (which is a little gem).
The DA 18-135 is quite capable, is WR and saves a lot of lens changes.
Another option is the DA 20-40 f2.8-4 Ltd, which is also WR, fairly compact and light weight (283g), with that Limited magic. It could even replace the 21, 35 and 40.
As for the body, I have both the K-3 and KP. I love the ergonomics of the K-3 (and the burst rate for birding), but honestly the image quality from the KP is a generation ahead. It gives an extra stop or more of usable ISO and the shake reduction is much better. Plus the tilting screen is a boon for tripod use and for shooting from awkward angles. It's only about 100g lighter than the K-3 (with the battery in each), but the difference feels significant.
My preferred walking kit is the KP, 15, 20-40 and DA 55-300 PLM - all fits in one bag, can do it all and is high quality all the way. If you don't need telephoto, KP + 15 + 20-40 is 700g + 190g + 283g = 1173g, compared to 800g + 565g = 1365g for the K-3 + 17-50 and the KP kit would be much more of a pleasure to use.
