Originally posted by jspi Even with a field monitor and magnified live view, the Rokinon isn't sharp. Tried indoors with a test chart and it was still fuzzy. It's the only lens I can't get focused.I'm getting several suggestions I'll have to review in the coming days. No rush to buy.
I would never use my 8mm fisheye lens wide open, but at f5.6 up to f8 (beyond that I start to see diffraction) you should get sharp images with it. What I did notice: for a final judgement of image sharpness of this lens always check on your monitor at home and not the preview of the camera, because of the way the preview image is processed in the camera the images look way softer in preview than they do on my PC (I shoot RAW not JPG).
It happens very often, especially with my 8mm and my 35mm lenses from Samyang, that I initially think all pictures are out of focus or otherwise soft when watching the preview and they turn out to be nicely sharp after importing to LR.
As others have mentioned you also have the possibility to stitch images together to get a wider field of view. (If you use Adobe CC you have a stitching software already included in LR if I am not mistaken; I use an older version of LR so I use Hugin for stitching which is a freeware, but there are many more programs you can choose from)
Especially for landscapes where in my experience tends to be not much movement stitching is a viable solution (but try to keep steel ropes or power cords in a single image of the stitch if possible, those make the most problems for the software in my experience).
For astro work stitching will be still possible but I assume it will be easier to get it right in a single shot, so you might consider a wider lens for this usage.
Here is an example for stitching (I think I stitched this from 39 single images):
and some more if you are interested:
Stitches | Flickr
