11-02-2008, 12:59 PM   #1
Big Dave's Avatar
M-Lens vs M42 type
Hello.
Yesterday I took my trusty FA-80-320 to the airshow here in Alamo City,Texas,USA. since my lens has stopped commicating with the camera, I had to use the AEL exposure lock and manually adjust the correct exposure. Needless to say my results were inconsistant. This is a big disadvantage of the M-type lenses. The M-42 type gives up auto diapharm for AV mode auto exposure with exposure compenation. Since I use long lenses in bright light, auto diapharm isn't a big deal to me. I didn't want to invest big bucks to repair my 80-320, so I decide to modify it to work in both M42 and M modes. I carefully taped off all lens openings and drilled and milled a new detent hole in the mount flange. It is located 6mm before the standard detent hole. In this position the camera diapharm actuator doesn't contact the lens lever. See photo. Now I can use it both ways, but I really prefer the M42 position for better ease of use. After testing it around the house, I am a happy camper. I'm leaving right to go shoot the Blue Angeles this after noon.
Dave
PENTAX K100D Super  Photo
11-02-2008, 04:30 PM   #2
Big Dave's Avatar
Well, I got the shots that I wanted and it was much easier using AV mode.
Dave
11-07-2008, 12:30 PM   #3
Big Dave's Avatar
I seen a thread recently, where people actually cut off the diapharm lever on their M series lenses to allow AV mode. Well, my solution of drilling an extra latch hole in the bayonet allows you to still have both options. The new hole allows AV mode and the original hole gives auto diapharm with AEL(green button) exposure fuction. If you decided to change back later, a drop of solder or JB Weld will fill the new hole.
Dave
11-07-2008, 03:26 PM   #4
Voe
Voe's Avatar
This is a very geniuos solution to a problem that was drawing me away from M lenses. Thanks for sharing!!
11-07-2008, 11:15 PM   #5
Initially, you lost me Dave, but after re-reading your message the light finally came on. You modified your mount so that the lens is not fully seated. Cool idea.
11-08-2008, 10:19 PM   #6
Brilliant! I think I'll be doing this to several of my M lenses, then I can use AV on my MG and my GX-10.
11-09-2008, 06:17 AM   #7
Big Dave's Avatar
Hi,
I'm glad that you guys like the dual detent idea. It sure makes life with my manual lenses more enjoyable. The only time that I need to open the appeture to focus is in low light with a flash. In those cases I usually use a fully auto lens anyway. Of course this idea won't work with lenses that lack an appetture ring.
Cheers, Dave
auto, exposure, hole, k-mount, lens, lenses, m42, pentax lens, position, slr lens, type
The right type of M42-to-K-mount adaptor dosdan Accessory and Memory Articles 19 08-11-2016 07:04 AM
What type of lens is this? yusuf Pentax SLR Lens Discussion 4 10-31-2010 07:04 AM
New type of generic M42 adaptor? AMBIVALENCE Pentax SLR Lens Discussion 27 05-18-2010 12:25 PM
Lens hoods - Why use them? How to know what type to use? noahpurdy Troubleshooting and Beginner Help 12 12-05-2009 11:30 AM
M42 Adapter: Can this type focus infinity? jocko_nc Pentax SLR Lens Discussion 6 05-08-2009 05:58 AM
All times are GMT -7. The time now is 12:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
