Originally posted by Lowell Goudge This is a feature of all Pentax Legacy lenses.
The first and last clicks are full stops, all other clicks are half stops. Most 3rd party lenses don’t have half stops
Technically, the first click on the K 500/4.5 is 2/3 stop to f/5.6 followed by half stops until f/16 and a full to f/22. Other lenses where the first stop is other than on a full stop vary a bit. Examples from my shelf:
- First variant ST 55/1.8 has a 1/3 stop to the first click (f/2.0) and half stops all the way to f/16
- Last version ST 55/1.8 has 1/3 stop to the first click (f/2.0), a full stop to f/2.8 and half stops from there to f/11 then a full stop to f/16.
- S-M-C Tak 28/3.5 has 1/3 stop to the first click (f/4), a full stop to f/5.6, and half stops from there to f/11 and then a full stop to f/16
- SMC Tak 50/1.4 is as you described
- Pentax-K 55/1.8 has the same pattern as the last version ST 55/1.8
- Pentax-M 200/4.0 is as you described
To be honest, I was surprised to see the variability given that the pattern as you described is pretty much Pentax "canon".
Interestingly, all of my Vivitars and Adaptall-2 Tamrons have half stops between full stops with a full to the minimum aperture with the exception of my Vivitar 28/2.8 in Exakta mount; it has clicks at all half-stops. The CZJ lenses have clicks at all half stops too. I am pretty sure that the only lens line I have that lacks half stops are my various Rikenons. Even then, I suspect the XR 200/4 and XR28/2.8 are set up the same as their Pentax-M twins.
(...anyone guessing I am bored silly would be correct...)
