Originally posted by rogerstg Congrats on the great shot!
FWIW, a technique that I use is to put the ball head all the way over into the detent and mount the lens to that. Leave the tripod collar slightly loose so the camera can be leveled and leave the ball head slightly loose to be able to adjust aim up and down. You need a sturdy ball head to make this work well. It gives you flexibility to follow movement similar to a gimbal head.
A camera safety note: the release plate should be angled so that the plate release knob is pointing up and not down. If down, it can rub against the monopod or ball head body and loosen the release plate.
Thank you!! OK I need to figure out what a detent is and figure out the specifics of what you're saying here. I have had this tripod for one week
and it's my first one, I appreciate the notes though and will look into it all.
---------- Post added 06-16-20 at 06:49 PM ----------
Originally posted by pschlute That is a big lens to hold steady without a monopod or tripod. In less than ideal lighting conditions you may struggle to keep the shutter speed up high enough. At 450mm you should not be using slower than 1/500 even with SR enabled.
Wow, lots to unpack here, thanks for all of it!! I've been using it handheld down to around 1/300, not always successfully, mind you, I'll lower my threshold on that.
Originally posted by pschlute A few things you can try are:
Use TAv mode. This will allow the shutter speed and aperture to remain constant and ISO will change according to the light. The K1 has excellent high ISO capability. A slightly noisy sharp shot is better than a noiseless unsharp one. Noise can be dealt with in PP software processing.
If your ISO is too high , dial in maybe -1/-1.5 of underexposure. Then bump up the exposure in PP.
I've been nervous about using too high ISO but you're right. I did use 10,000 ISO in the woods recently and got some great, if a little noisy, shots of an owl that were stone still. I've also only been shooting on Av but will try TAv, I kind of forgot about that option. I'd also forgotten about exposure compensation until about 3 weeks ago but am now using it pretty consistently, to good effect. Good reminder about TAv.
Originally posted by pschlute Do some Autofocus testing at home with the camera on a tripod (use 2 second timer) to make sure your AF is spot on. If there is any Front or back focus issues you can adjust with the AF/FA (auto-focus/Fine Adjustment) menu.
I read about this possible issue on this forum but haven't tried such a test, I don't quite understand how to test it but will look for a step by step and try it
Originally posted by pschlute I see you use Photoshop , Adobe Camera Raw. Are you applying any output sharpening to your images ?
I play with noise reduction by adjusting the Luminance setting, have used it pretty consistently. But I don't understand the other sharpening tools. I tried changing the sharpening amount and tweaking some of the sliders in that section and honestly thought it all looked worse so I can't say I have a real understanding of how to use it. It's on my list of things to investigate. Post processing in general is something I am just really starting to spend more time doing and I learn a little more every time but there is so much to learn! Hey, thanks again, I appreciate you taking the time to give me these tips.
---------- Post added 06-16-20 at 06:52 PM ----------
Originally posted by RICHARD L. Experience teaches you where a particular lens will perform at its best. For example, my FA* 300 mm f/4.5 peaks at f/8, its performance doesn't get any better if I stop-down more, so no use for that. Exactly the same with my 67 M* 300 mm f/4 lens: f/8 is its optimum f/stop. I just got a new for me, second-hand DA 55-300 mm f/4-5.8 HD that I tested on a tripod at all apertures and focal lengths on an old flour mill (that serves as my "brick-wall" target) and I found f/11 is optimum up to 200 mm FL and f/16 is best at 300 mm FL. So simply take the time to test your lenses on a fixed subject like a building at all apertures in controlled conditions (ideally on a bright day with a tripod) and determine their best performance range for your usual shooting conditions.
Regards
I have this exact test on my to-do list! Time to get methodical. Thanks
---------- Post added 06-16-20 at 06:55 PM ----------
Originally posted by MossyRocks I wouldn't try to hand hold my 400 but then it is a special monster and I am a big guy who was big into power lifting for years.
I do a lot of crawling through the woods looking at teeny songbirds so it's not always practical to carry and/or use a tripod. I will be carrying the monopod most of the time now, to use in more challenging lighting conditions, at least.
---------- Post added 06-16-20 at 06:58 PM ----------
Originally posted by ramseybuckeye I'm impressed with getting any tern in flight.
RIGHT?! They're so dang fast, and they do barrel rolls at a moment's notice. They're ever so slightly easier than swallows, though, which I was obsessed with trying to capture in flight but settled for really good stills while perched. Why couldn't I be obsessed with photographing, say, Robins
