Originally posted by Cerebum I calibrated my 50-200mm and the improvement was stellar. I want to do all of them but it is a bit of a FAFF. Well, I began to wonder, would it be possible to calibrate a lens using focus peaking? If you had something fixed and graduated like a steel ruler, or for that matter, anything with a regular texture, my thought is you could focus the lens and live view would show you what is in focus and what isn't. From that you could see if it is front or back focusing without having to upload the image. So, the question is, would that work?
I think you can check the focus accuracy of a lens to an extent doing what you say, but I'm not sure there is an easier way to actually calibrate the AF than the old school and, as you say, somewhat clumsy method we've been dealt.
I've found that I can zero in on accurate AF with not too many steps, most of which are done off the rear screen, but at some point, you want to bring the file up on a monitor and look at the pixels.
Here's what I do:
Set the AF offset to -3, then 0 then +3, taking a picture of a flat target a reasonable distance away. Target distance will vary based on focal length, if I am doing a wide angle, it will be fairly close, a telephoto, not so much.
Anyway, use the rear screen to see which is sharpest and repeat the test using that number as the center point. Drop the variance to -2, 0, +2 from the new center point.
Repeat the process, zeroing in closer to perfection. It shouldn't take very many steps to get there.
My last step is a -1, 0, +1 from my new center point. This one I put on a computer screen to pixel peep.
The most steps I've had to do using this method is three in camera and a final one on the computer screen.
Back in my days of running photo labs, this was called a ring-around, and was used for everything from helping to determine the aim point on a colour printer to setting the focus on lenses.
Hope this helps.
