Even though they are vastly different lenses as well as being budget vs premium I suspect the aperture lock and pin mechanism are similar. You may want to review the photos of the Pentax-A SMC 50mm f/1.7 lens in the following thread:
Pentax-A 50mm f1.7 Aperture ring repair - PentaxForums.com
Several possibilities (and perhaps in combination) come to mind::
- The "click-stop" ball bearing and/or spring popped out and are jammed under the ring.
- The "A" button slipped under the leaf springs
- The "A" pin assembly slipped out and jammed under the ring.
- The linkage between the ring and iris mechanism is out of place
I'm afraid there is nothing to it but to use a reasonable amount of force the remove the ring. I suggest you do this in a plastic bag so as not to lose any of the tiny parts like the ball bearing, spring, button and pin assembly.
Otherwise as this is a high value lens you may consider having it professionally serviced.
