Originally posted by Jonathan Mac Some photo uploads to Flickr, for example with my Fujifilm cameras, seem to show the full name of the lens used. Uploads from my Pentax cameras (K3 & K200D) do not, just showing the aperture, focal length etc. It can be a bit annoying when I'm trying to work out which lens was used,
Is the lens name hidden away somewhere in a non-standard-format field of the exif or is it not recorded at all?
I've seen some uploads from Pentax cameras that do show the lens name, but perhaps they're being added manually by the photographer before uploading.
Many thanks
What software are you using to process your photos? If you are using an older version make sure you do any updated as new lenses have to be added. I use Lightroom and have no problem, but if I directly upload a jpg from the KP, the lens does not show up. So I just did an unscientific experiment right now with a photo captured using RAW+jpg. I took a photo that I uploaded this afternoon to Flickr, that did not run through Lightroom, I had only viewed it though Digital Camera Utility 5. So I went back in to DCU5, saved the jpg photo to another folder, imported to Lightroom, and exported with no changes, and uploaded to Flickr, and it shows the lens. So it looks as though Lightroom is possibly "standardizing" the EXIF, much like
selfnoise is doing, although automated. Just to note, the LR jpg was smaller than the Pentax jpg, so it is recompressing the file.
