Originally posted by david94903
Oh wow! Thank you for that tip, David! Please see attached. Several things to come to mind:
1. The 50mm on the camera has a 49mm filter dia and the Vivitar has a 52mm, so I couldn't actually connect them with a ring (don't have one yet). So I held them together with one hand.
2. I removed the broken iris on the Vivitar (tried to remove just the bent blade, but then everything went kaput, so I removed them all). So the "objective" lens is wide open (35mm F2.8). The Pentax was stepped up (down?) to 2.8.
3. Wow, one needs super steady hands to manually focus in this configuration.
4. What's with the very narrow in-focus area? The sweet spot's like a thin strip across the lens.
5. Quite a bit of vignetting.
Any tips on how to hold the camera steady? I'm quite ecstatic even with these initial results. Am buying an adapter ring right away!
Thanks again! I now have a use for that Vivitar.
