This sounds a bit like you have trash on the autofocus module lens. This is common, my K-3 has this problem occasionally. if you have a Rocket Blower set your K-70 for mirror up with the lens removed and turn the lens mount opening face down then blow into the area of the mirror box where the autofocus module is located, its at the bottom of the mirror box. Try not to touch anything, give it several shots from the Rocket Blower. Then turn the camera off and let the mirror drop and while still holding the camera face down blow around the inside of the mirror box and hopefully what ever trash is in there will be dislodged.
Reason: clarity
