Hello, Jolly Green. I had decided to stay out of this but your thread has taken a few unintended turns and I thought it might help if the external differences between the 7 and 8 element lenses were explained. @Wasp posted an image of two lenses – the 8 element on the right in his image and a supposed “hybrid” 8 element on the left. I have reproduced them below with the aperture ring/hyperfocal distance scale of the 8 element on the left and the supposed hybrid on the right. In the middle is the aperture ring and hyperfocal distance scale of the 7 element version (taken from the Pentax Forums site).
I am told there has been a lot written about “hybrids”. But there has also been a lot written to “prove” that the moon landings were a hoax.
Let’s just deal with what is on the hyperfocal distance scales of these lenses. You will note that the 4, 8 and 16 marks on the scale are the same to the right and left of the red diamond. They have to be symmetrical. Hyperfocal distance is exactly the same in front of and behind the focal plane. There is also a red IR mark.
On the 8 element version (left, below) the IR mark is just to the right of the 4.
On the 7 element version (centre, below) the IR mark is just to the left of the 4.
These differences are well known and they are a recognised way to tell the 8 element and 7 element versions apart.
On the supposed “hybrid” lens (right, below), the red IR mark is directly above the 4. In fact, it covers what would normally be the white 4 mark on a 7 element lens (compare it with the 7 element in the centre). Just to the left of this (where the red IR mark would normally be) is a white mark. What does it represent? Clearly it does not represent the 4 for the hyperfocal distance scale or there would be no symmetry in the distance between the 4 and 8 marks on either side of the red diamond. What has happened here with the supposed “hybrid” is that someone has taken a 7 element version, painted the white 4 mark red and overpainted the true IR mark white.
You can change aperture rings and switches and other stuff on a lens (if they fit) but that does not make it a “hybrid”. A true hybrid would have a different set of lens elements and groups. The 8 element has 8 elements in 6 groups (one group being the expensive “triplet”) and the 7 element has 7 elements in 6 groups (see below).
We can’t just swap elements in and out of a lens to create something new and expect it to perform to a certain spec. Optics is a science. But we also know that if the lens on the right above really is a hybrid, some of the lens elements or groups
must be different to both the standard 8 element and the standard 7 element. Something
must have been changed in the optics for the IR mark to have shifted.
Either that or it didn’t shift – a new IR mark was just painted on.
I know where the evidence points, but anyone is entitled to draw their own conclusions. I will also point out that the supposed “hybrid” has the same rear element presentation as the 7 element version. I believe the “hybrid” is just a doctored 7 element lens.
But I am willing to be proved wrong if someone can put up the “hybrid” elements/groups schema. The invitation is there for anyone to take up. It seems like a lot of trouble to go to for a lens that is not particularly rare (and I can't see how anyone could fiddle with the cemented triplet). But it would still need to go into the database.
I hope this helps in your search for an 8 element Takumar 50/1.4
Peter
