11-05-2008, 03:21 PM   #1
Pentax 17-70 f4?????
Does anybody out there have this lens? I'm upgrading to K20d, and don't know if I should go the 16-45 f4 vs Pentax 17-70 f4. Is it worth the extra money???
11-05-2008, 03:58 PM   #2
rburgoss's Avatar
I dunno. The Da16-45 is one of the best wide to short tele zooms out there. It is fully compatible with all Pentax DSLR's. The newer DA17-70 is SDM Only, meaning it will not AF with istD* series bodies. I am sure the extra mm at the long end will come in handy, but at almost twice the price, I would consider the purchase.
If I had the money to get the 17-70, (and not have the DA16-45) I would look into the DA* 16-50 a little closer. It is a lot faster, sealed, SDM and screw AF, but then, there are many bad copies roaming this world... nevermind
Robert B
11-05-2008, 04:00 PM   #3
Ben_Edict's Avatar
I have been contemplating this lens too. German photo magazine "Color Foto" has reviewd it very favouribly, even with better IQ than the 16-50 and at least matching the performance of the 16-45. If this is true, the 17-70 is by far the better buy.
Ben
11-05-2008, 05:06 PM   #4
QuoteOriginally posted by mokey Quote
I had the 16-45 some time ago and sold it. I was less impressed than a lot of other owners - it seemed very soft at the edges at wide angle. And I hated the way it extended at wider angles. Felt all wrong, a trivial point though that might seem. For the money I didn't feel it offered enough advantage over the kit 18-55. Although the Sigma 17-70 is a bit big and heavy for my taste, with a scarily large front element, it performs better than my 16-45 did, with a more useful range thrown in. But the first two Sigs I had were dud copies, so good luck if you go in for that particular lottery. Don't know about the Pentax 17-70 - sounds as if that too is a bit variable, and it's certainly not cheap.
Not very helpful, sorry - after a lot of frustration and money spent, sometimes I come back to thinking that the 18-55 is in fact the best available combination of lightness, compactness and reasonable quality for a standard walkaround zoom, if all those factors are important to you.
11-05-2008, 05:12 PM   #5
thx I checked out the color foto website (a better knowledge of the german language was necessary)
I'm pushing the budget already to get the 17-70, so I'm not sure if pushing it any further for the 16-50 f/2.8 is wise. I have the 50-135 f2.8, and I absolutely love it. Agh
11-05-2008, 05:16 PM   #6
QuoteOriginally posted by timo Quote
you know , I agree with you regarding the 16-45. My friend has one, and I tested it against my 18-55 at the time , and I didn't find $300 difference. Maybe I should just go with the new 18-55 II that comes with the k20d. (my original 18-55 had a mishap with the k10d-thus I'm on to new and hopefully better things)
11-05-2008, 07:52 PM   #7
Wheatfield's Avatar
I tried one, it had more barrel distortion at the wide end than I was comfortable with.
11-05-2008, 08:24 PM   #8
If the price drops 40% i'd consider one. Until then there are far too many good 16/17/18 to whatever lenses available.
11-05-2008, 08:27 PM   #9
how about the Sigma 17-70?
DA17-70 side by side with Sigma 17-70: Pentax SLR Talk Forum: Digital Photography Review
11-05-2008, 10:04 PM   #10
that was a great thread-took me awhile to get thru it-very informative
I still don't know what to do. I'll maybe try out what they have in store for feel, and hope I get a good one of whatever I choose.
thx for the info
11-06-2008, 01:07 PM   #11
audiobomber's Avatar
Not my experience at all. I replaced the 18-55mm with the 16-45 and I couldn't be happier. Brighter, better colours, sharper by far. Maybe you tried the 16-45 on a 6mp camera? The K20D really shows up the difference in sharpness.
11-06-2008, 06:45 PM   #12
thx for the info
There is a 17-70 siggy ont he marketplace for $300.
Bargain.
11-06-2008, 07:17 PM   #13
thx I'll check it out. It's one of my choices, but I just can't seem to make up my mind. and I pick up the 20d tomorrow. decisions decisions
I've already got a 50mmf1.7 ,50-135mmf2.8(LOVE THIS LENS), 100-300 , 12-24 f4, and an old 100 f4 macro.
So now I'm possibly considering just getting the kit lens with it, and picking up a Pentax 24-90 off of ebay (agh)? Any thoughts?
11-07-2008, 02:47 AM   #14
Ben_Edict's Avatar
Given the lenses you already have, it might be a good idea to go for a 18-50/2.8 Sigma instead of the kit lens. I have the older non-Macro version of the Sigma and can only say, that it is sharp and contrasty and well useable even fully open. It is quite small and lightweight, much smaller indeed than the Pentax 16-50 or the 17-70.
Ben
11-07-2008, 07:49 AM   #15
first tests of 17-70
I have this lens since June and am learning about its strenghts and limitations. It has some strange characteristics which I am starting to understand. I'll post some test shots when I have some spare time (year end is tough jobwise)...
It has a great snappy contrast, colors are great, weight and look are perfect, autofocus is smooth and fast and silent. I don't see centering defects in my copy.
Optically it has some inverse behavior at shorter and at longer focal lenghts, which is perhaps intentionnal by design.
Longer focal lengths (>35mm): a bit sharper than my DFA 100mm macro at f11-f16; but very soft up to f11 (there is a jump in sharpness past f8) and at f22. Sharpness at f8 about the same as at f4! Sweet spot is f11 where it shines.
17mm focal length: very soft at f4 but a bit sharper than DFA100mm stopped down (even at f5.6 which is the sweet spot) up to f22. It produces stunning landscapes stopped down 1 stop or more.
So knowing that I have been able to get very sharp and snappy pictures. But it is not what the tests in CI showed... so I believe there is some variability from lens to lens.
I have started to notice some problems locking focus af 70mm even in good light and contrast, perhaps it is due to the softness at f4? (advises welcome.) But I may send it to Pentax repair because 1) it is very annoying when you press the shutter and cannot take the shot; 2) it is not normal, I think, that it is so soft at f8 for longer focal length.
f4, k-mount, pentax, pentax lens, slr lens
All times are GMT -7. The time now is 12:15 PM. | See also: NikonForums.com, part of our network of photo forums!
