Originally posted by dlh
secondly, there's no way to lock the zooming part, which, if I have it extended towards the greater telephoto range, it tends to slide back in if it's pointed upwards (e.g., attempting to track birds in flight).
The zoom can creep when the lens is pointed up or down, more so when the lens has had a lot of use and the seals are less tight, but it won't/can't creep if you hold the zoom ring, which to me is a natural way of holding the lens and allows you to rapidly re-frame as required, so I'd say it's not an issue if hand holding.
Cheers,
Terry
