10-20-2020, 07:41 AM   #16
ramseybuckeye's Avatar
QuoteOriginally posted by Prince Harbinger Quote
I'm not one for showing off. The character of the lens is the only thing that appeals to me. I created the thread to find out if the lens is worth purchasing in it's current condition. If the issue is only fungus, and dust I'm able to resolve it.
Thatís whatís hard to tell, it looks like it could be separation.
10-20-2020, 09:22 AM - 1 Like   #17
QuoteOriginally posted by ramseybuckeye Quote
There's no separation.
Here's some more photos.
Dropbox - Screenshot_20201020-120306_eBay.jpg - Simplify your life
Dropbox - Screenshot_20201020-120301_eBay.jpg - Simplify your life
Dropbox - Screenshot_20201020-120249_eBay.jpg - Simplify your life
Dropbox - Screenshot_20201020-120240_eBay.jpg - Simplify your life
Dropbox - Screenshot_20201020-120230_eBay.jpg - Simplify your life
10-20-2020, 09:39 AM - 1 Like   #18
Fenwoodian's Avatar
From these recent photos that you posted, the fungus etc inside the lens does not look so bad.
I've cleaned many lenses with fungus in them. Heavy fungus sometimes can not be effectively removed. However, lighter infestations of fungus can often be successfully removed. From these last photos you've posted it now looks like it's likely a lighter concentration of fungus that can likely be effectively removed.
The outside of the lens and the rear element look nice.
So, given the nice condition of the outside, the good condition of the rear element, the light concentration of fungus, and your declaration that there's no separation, then based on this new information, I'm changing my recommendation to BUY. While it's not "collectors" quality, if you think you can clean up the optics and remove the light fungus you just might end up with a nice "shooter lens" (provided the price is acceptable).
Let us know how it cleans up. Also, it would be nice to see some photos you take with this lens.
10-20-2020, 09:46 AM   #19
Otis Memorial Pentaxian
The lens is M42 and has a rear element. If you want it, buy it. As for what we might advise based on what you have shared, I would not buy the lens nor advise you to buy it without knowing its make and model.
10-20-2020, 09:56 AM   #20
These look way better.
10-20-2020, 10:55 AM   #21
QuoteOriginally posted by Fenwoodian Quote
I really appreciate you taking the time to have a look at this lens and point out your findings. Before you change your recommendation. What do you think this is on the front element? I'm thinking it might be grease? Maybe fungus? Doesn't appear to be coating damage.
Dropbox - 20201020_133814.jpg - Simplify your life
Dropbox - 20201020_133905.jpg - Simplify your life
Dropbox - 20201020_134016.jpg - Simplify your life
Dropbox - 20201020_134057.jpg - Simplify your life
Dropbox - 20201020_134137.jpg - Simplify your life
Dropbox - 20201020_134321.jpg - Simplify your life
10-20-2020, 11:43 AM - 1 Like   #22
Fenwoodian's Avatar
Hard to tell from those small, low res photos.
You said - " I'm thinking it might be grease?". Grease is often easy enough to remove. However, sometimes what looks like "grease" is actually "haze". Like fungus, I've found that sometimes haze (especially if it's been in place for years ) can be impossible to remove.
If this lens is in your possestion, why don't you just remove the front element and try to remove the grease/fungus yourself? Keep the lens if you are successful, return it if not.
For most lenses, front elements that are a functional total loss are not of much concern to me as I can usually (with enough time) find a cheap donor "for parts" lens and it's easy enough just to swap out front elements.
However, if this lens is that rare, you might have to wait a LONG time to find a cheap donor lens with a nice front element.
10-20-2020, 12:03 PM - 1 Like   #23
Fenwoodian's Avatar
Also, check out my Flickr "Swirly Bokeh Gallery" to see 175 outstanding examples of swirly bokeh AND the lenses that took them (I wonder if your rare swirly bokeh lens is included?).
10-20-2020, 02:12 PM   #24
I don't have the lens yet. That's what I plan to do. I don't think it would be a good idea to swap this element with a donar one. As the donar element won't produce the swirl. Now if I find another copy that's a different story. I thought of actually doing that with the Helios 44 taking the front element and placing it in a body that does F/1.2 I'm curious how the results would turn out wide open. Anyway, that's an experiment for a different day.
---------- Post added 10-20-20 at 02:14 PM ----------
Beautiful examples. I looked at all of them. I liked three of the lenses from that series of examples. None of them were from my lens.
11-02-2020, 08:58 PM - 1 Like   #25
FotoPete's Avatar
Photo 134137 def looks like some seperation. Those ripples looks like the balsam in retreat from the edges. Unfortunately, time is working against these lenses, if it's a curiousity, I'd pass on this one.
bokeh, donor, ebay, element, elements, examples, front, fungus, k-mount, lens, lenses, pentax lens, pm, post, scratch, slr lens, spots, time
Don't buy yet another lens, buy a newer monitor! mee Digital Processing, Software, and Printing 15 03-04-2019 01:05 PM
K-5 iis give me lens anxiety, which lens should i buy? SMeK Pentax SLR Lens Discussion 20 11-27-2014 08:38 AM
Should I buy this laptop to speed up my workflow or buy a new lens? crossover37 Pentax SLR Lens Discussion 26 09-24-2010 09:41 AM
Should I be a good Pentax choirboy and buy a DA 15 Limited or buy the Sigma 10-20mm? tokyoso Pentax SLR Lens Discussion 42 03-14-2010 04:54 PM
Going camping. Should I bring my AF-360fgz? Macro lens? What should I bring? igowerf Photographic Technique 11 08-17-2007 07:48 AM
All times are GMT -7. The time now is 11:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
