EDIT Oct 26 9:00am AEST: Sorry for the trouble viewing the photos - I'm a bit out of my depth. I think the problem stems from the browser used to view the photos as I use MS Edge and I can see the header with each photo underneath but when I open the post with Google Chrome then no photos. I will try to attach the photos at the bottom of the post without the headers. Please also note that there is a limit of 15 photos so I have not shown "8. K3 & DFA150450 & TC (975mm) SOOC"
I currently have a Tawny Frogmouth nesting in a park nearby and hopefully that means a TF chick or two in the near future, These chicks are very cute and the nest is in a good position to photograph so I am hopeful of getting some nice photos. I am wanting to photograph from about 25m from the nest so as not to disturb the birds and they are generally not shy birds and not showing any nervousness at that distance. I generally use my K1ii and DFA 150450 for bird photos but I wondered if my K3 & DA 300 with or without TC might give a better result. Before I got the K1 and DFA, I used my K3, DA300 and TC and was generally pleased with the results but I have never tried to compare the two kits. With the new babies coming soon, I thought I would do a trial of the combinations and see what differences there is for this application. I see others on this forum asking about this comparison so I thought i would share my results.
For both the K1ii and K3, I took 3-5 photos with each of the DA300 and the DFA 150450 and then with each lens with the DA1.4x TC - a total of 8 permutations.
All the photos were shot using Tav and 1/500 and F8. The weather was slightly overcast but there was a little variability in light so that ISO's wandered around a little. The RAW files were imported to LR classic, some slightly adjusted for exposure but no other PP, and then exported at 1MB 1400x900 for the Forum.
Each photo was also copied and cropped to roughly the same field of view to see the differences in performance.
1. K1 & DA300 (300mm) SOOC
1a K1 & DA300 (300mm) Cropped
2. K1 & DA300 & TC (420mm) SOOC
2a. K1 & DA300 & TC (420mm) Cropped
3. K1 & DFA150450 (450mm) SOOC
3a. K1 & DFA150450 (450mm) Cropped
4. K3 & DA300 (450mm) SOOC
4a. K3 & DA300 (450mm) Cropped
5. K1 & DFA150450 & TC (630mm) SOOC
5a. K1 & DFA150450 & TC (630mm) Cropped
6. K3 & DA300 & TC (630mm) SOOC
6a. K3 & DA300 & TC (630mm) Cropped
7. K3 & DFA150450 (675mm) SOOC
7a. K3 & DFA150450 (675mm) Cropped
8a. K3 & DFA150450 & TC (975mm) Crop
My conclusions are that the cropped photos were all similar with no clear winner. All performed very well. TBH I probably had more variation in the 3-5 shots with each setup than between the various body/lens/TC combinations. I see slight losses in sharpness when the TC was used, more so with the DFA150450 . The sensor on the K3 is noticeably noisier than the K1 but the sharpness on the crops was as good or better (higher resolution sensor?). If it was a KP or a Knew instead of the K3 then maybe the sharpness might exceed the K1?
So moving forward I will keep using the K1 and DFA150450 without the TC and crop the photos - more for its advantages of zoom & AF than any IQ benefits.
Reason: Photos were not viewable in some browsers (MS Edge works but not Chrome and others?)
