Originally posted by UncleVanya Birding is many things to many people. Maybe a bit more info on the size bird and the photo desired. Also will you crop tight or do you need the environment to be showcases also? Maybe example shots - even if from others - will help.
Originally posted by alfa75ts If I've got it right, this should give you some idea what you can expect to see through a 300mm lens.
You both have said it. Many birds are less than the 150mm / 6 inch dimension indicated in the sketch shown.
I shoot with the DA560 and crop heavily at times.
also remember an APSC sensor is 24 mm wide x 16 mm high
300 mm may leave you feeling a little short.
Just my $0.02
But just for comparison, consider that not all birds are created equal, some herons exceed 3 feet (900mm) In length.
Depending on what the op wants to shoot I recommend committing the following to memory
Image size = subject size x focal length / distance
