Show Printable Version 10 Likes Search this Thread
11-01-2020, 09:12 AM   #16
angerdan's Avatar
QuoteOriginally posted by someasiancameraguy Quote
I'm hoping to expand my collection of glass that suits portrait photography, but I find the CA coming off the 77Ltd a bit distracting and the new DFA* 85mm prohibitively expensive.
What other choices aside from the 100mm Macro would you guys recommend with little to no CA?
I'm open to third party glass recommendations too as long as they work on both film and DSLR bodies.
The CA of the FA 77mm can be corrected inside the camera.
D FA* 50mm with the 2021 FF converter. Quality of the D FA* 85mm with lower weight.
But the D FA 100mm Macro is a very good choice, especially if you want to change the aperture on analog bodies.
Or the F(A) 85mm f2.8 Soft.
https://www.pentaxforums.com/lensreviews/SMC-Pentax-F-85mm-F2.8-Soft-Lens.html
https://www.pentaxforums.com/lensreviews/SMC-Pentax-FA-85mm-F2.8-Soft-Lens.html
11-01-2020, 12:03 PM   #17
I like the results with the Tamron Adaptall SP2 90mm, a little heavy but easy to use.
Mike
11-01-2020, 12:18 PM   #18
No direct experience, but a few people have said that the the DFA 100 Macro can exhibit CA wide open.
If not too long there a lot of 135mm vintage options.
11-01-2020, 12:42 PM - 2 Likes   #19
ZombieArmy's Avatar
The Samyang 135 f2 is probably one of the most gorgeous portrait lenses I've seen for the price.
11-01-2020, 01:10 PM   #20
angerdan's Avatar
QuoteOriginally posted by ZombieArmy Quote
Do you know if the TO is interested in MF lenses?
11-01-2020, 01:20 PM - 1 Like   #21
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by angerdan Quote
In post #4 of the thread he says that he prefers AF...
11-01-2020, 07:44 PM   #22
ChristianRock's Avatar
I have seen a few Sigma 85mm f/1.4 lenses coming up for sale lately... that would be an option.
CA is usually correctable in post or even in-camera if you shoot jpeg, so are you sure it's not just a nit pick?
11-01-2020, 07:54 PM   #23
pres589's Avatar
There's a number of entirely different 90mm f2.5 macro's (and some rebadges of the same) that all seem good for this sort of thing. Tamron even had one with AF. Pentax's M 120mm f2.8 also seems good but it's MF. There's also the Pentax M 100mm f2.8 which isn't a macro. MF again like all of the M's.
I actually picked up an M 75-150mm f4 zoom for portraits but have yet to shoot any due to timing and the state of things lately. There are a number of zooms with a max aperture of f2.8 that would probably work well for this sort of thing.
11-01-2020, 10:28 PM   #24
Maybe get a Pentax A* 85mm f1.4 lens? A fantastic portrait lens and a great all around medium telephoto lens. If you get this lens you’ll probably not want any other 85 mm lens afterwards. It has a classical look and plenty sharp that it doesn’t look overly sharp either
11-01-2020, 11:42 PM - 1 Like   #25
Sandy Hancock's Avatar
If you want a fast short telephoto, and shoot it wide open, then expect to deal with chromatic aberration. Either work hard at your lighting, or work hard on your post processing.
The FA77 is superb. The FA*85 is arguably better. The DFA*85 won't work on film cameras, so you don't even have to worry about that one
11-02-2020, 12:11 AM   #26
Michail_P's Avatar
What about APS-C? Is there any affordable prime portrait glass?
Either af or mf, wouldn’t mind. The limited are nice but so goes the price.
11-02-2020, 12:16 AM - 2 Likes   #27
QuoteOriginally posted by mixalis_kalymnos1611 Quote
Any fast fifty can make a very decent portrait lens on crop. The FA50/1.4 has lovely out-of-focus rendering and colours, and a pleasing softness wide open, which is quite desirable for portraiture. The DA*55 /1.4 is another level up.
11-02-2020, 03:08 AM   #28
FreeSpirit9's Avatar
I have found the sigma 50 1.4 hsm ex to be excellent.
11-02-2020, 03:19 AM - 1 Like   #29
I know that CAs are generally quite easy to correct for in focus areas, but LoCA in bokeh can be unpleasant in high contrast situations. I'll be looking at the Sigma a bit more.
11-02-2020, 03:25 AM - 1 Like   #30
heinamj's Avatar
Cheers
Highly recommended Samyang/Rokinon 135mm F2 ED UMC... I can shoot straight into the stage lights. A joy to use it you're comfortable with manual focus. And one of the best astrophotography lenses out there for under $1000.
90mm, frame, glass, k-mount, macro, mm, pentax lens, portrait, post, recommendations, slr lens, tamron
Canon shifting their focus on intoducing mirrorless glass rather than DSLR glass lesmore49 Canon, Nikon, Sony, and Other Camera Brands 26 01-16-2020 09:21 AM
Recommendations for a good cheap 135-300mm MF glass BruceBanner Pentax SLR Lens Discussion 19 09-11-2019 03:30 PM
PENTAX new glass-old glass - lens tubes designed like old glass? corporate identity? camyum Pentax Full Frame 3 09-24-2017 02:52 PM
New glass - old glass. Which lenses should Pentax revisit? HopelessTogger Pentax Full Frame 204 09-07-2017 05:12 AM
Autumn colors - old glass is a good glass andrei46 Post Your Photos! 5 10-26-2007 09:35 AM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
